Philips Hue Surimu Rectangle Panel
Quicklinx: GSQHWS00 Mfr#: 929002966501
The rectangle Surimu ceiling panel features a soft, diffused glow of colorful light. Perfect for living rooms and bedrooms, the Surimu ceiling panel is easy to install and sits flush with the ceiling, filling the room with color.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Create a personalized experience with colorful smart light
    Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
Philips Hue White and Color Ambiance Surimu - ceiling light panel - LED - 1200 x 300 mm - 60 W - 16 million colours/warm to cool white light - 2000-6500 K - rectangle - white
Ceiling light panel - rectangle
Recommended For
Kitchen, living room, bedroom, home office
Standard Panel Size
1200 x 300 mm
Light Source Type
LED
Dimmer
White
Wattage
60 W
Wattage Equivalent
100 W
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
3350 - 4150 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth
AC 220 - 240 V
Ceiling light panel
Recommended For
Standard Panel Size
1200 x 300 mm
Shape
Rectangle
Dimmer
Protection class I, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
60 W
Wattage Equivalent
100 W
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
3350 - 4150 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Bluetooth
Voice Controlled
Indirect
Product Material
Metal, synthetics
Body Colour
White
IP20
Warranty
2 years
120 cm
30 cm
4.8 cm
5.7 kg
8.73 kg
