Philips Hue Runner Bar - White 2x5W 230V
Quicklinx: GVY6WS00 Mfr#: 929003045601
With a Philips Hue White Ambiance spot Runner included in your Philips Hue system you can enjoy natural white light that helps you to wake up, energize, concentrate, read and relax. A high-quality spot, built to last with attention to detail
  • High light output
    High-quality light with strong light output, providing plenty of white light for any moment or task.
  • Easy and wireless control with the dimmer switch (included)
    With the battery-powered dimmer switch for Philips Hue, you can control the light of your white ambience lamps easily. Cycle through the four different light scenes by simply pressing the on button, dim the light up or down and settle for ease of use. The dimmer switch can be placed anywhere in its small and elegant dock and needs no wiring. Use as a remote control or as a light switch against the wall and enjoy the right light recipe for every moment of your day. You can add up to 10 Hue lights to one dimmer switch.
  • Relax, read, concentrate and energies with light recipes
    Light influences our mood and behavior. Philips Hue can help you to customize your daily routines into moments that you can enjoy. Skip your morning coffee and get ready for the day with cool, bright-white daylight that helps to energies your body and mind. Stay focused with finely tuned bright-white light. Or put your feet up and relax with a soft glow of white light for the perfect end to the day.
  • Full control from a smart device with the Hue bridge
    Connect your Philips Hue lights with the bridge to unlock the endless possibilities of the system.
  • Create your ambience with warm white to cool daylight
    Set the right ambience for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice cool daylight of winter.
  • Wake up and go to sleep naturally
    Philips Hue will help to get you out of bed the way you like it, helping you start your day feeling refreshed. The light's brightness increases gradually, mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. Connection with the Philips Hue bridge is required for this functionality.
  • Smart control, home and away
    With the Philips Hue iOS and Android apps you can control your lights remotely, from wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late. Connection with the Philips Hue bridge is required for this functionality.
  • Set timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually during the night, so you never have to worry whether you've left any lights on. Connection with the Philips Hue bridge is required for this functionality.
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and Google Home to allow you to control your lights with your voice.
Philips Hue White ambiance Runner - spot light - LED spot light bulb x 2 - GU10 - 5 W - total: 10 W - warm to cool white light - 2200-6500 K - double - white
Spot light - double
Recommended For
Living room, bedroom
Light Source Type
2 x LED spot light bulb
Style
Modern
Supported Light Bulbs Qty
2
Total Wattage
10 W (equivalent 100 W)
Total Luminous Power
700 lumens
Dimmer
White
Socket Type
GU10
Wattage
5 W
Wattage Equivalent
50 W
Energy Efficiency Class
G
Colour of Illumination
Warm to cool white light
Colour Temperature
2200-6500 K
Luminous Power
350 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue, Nest, Echo
Communications Technology
Bluetooth, Zigbee
AC 230 V
Frequency Required
50 - 60 Hz
Spot light
Recommended For
Style
Modern
Shape
Double
2
Supported Light Bulb Wattage
5.5 W
Total Wattage
700 lumens
Position Adjustments
Swivel head
Dimmer
Protection class I, remote controlled, ZigBee Light Link, controlled via Bluetooth, app-controlled, 4 lighting programmes, voice control
Light Source
Socket Type
GU10
Wattage
5 W
Wattage Equivalent
50 W
G
Colour Temperature
2200-6500 K
Luminous Power
350 lumens
Lifetime
15000 hours
Power Requirements
AC 230 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue, Nest, Echo
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Product Material
Metal
Body Colour
White
Hue switch
Package
Box
IP20
Warranty
2 years
30.5 cm
8.9 cm
10.9 cm
960 g
36.5 cm x 14 cm x 14 cm / 1.312 kg
