This cool, contemporary Philips Hue Phoenix downlight lets you change its dimmable white light from your smartphone or tablet. Using the Philips Hue bridge (not included), this LED light connects to your home Wi-Fi network and lets you control its settings using an accompanying app. Whether you want a bright work light or some mellow mood lighting, this adaptable light makes it simple to select the lighting design you want - and it also comes complete with a 5 year guarantee.
Set the ambiance in your home with warm and cool white light
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter.
3D texture for dynamic effect
Philips Hue Phoenix has a special 3D texture that enhances its looks and gives a pleaseant diffusion of light. The surface of the lamp is covered with a hexagonal pattern that captures and reflects light, creating a dynamic effect. The effect changes depending on your viewing angle, making Philips Hue phoenix an eye-catching piece of decoration in your home, even when the lights are off.
What's in the box?
- 1x Philips Hue Pheonix PErsonal Wireless Lighting LED Ceiling Light
4 light recipes
Get the best light for whatever you do. Philips Hue has captured the optimal light for your daily activities in 4 light recipes. "Energize" bathes you in cool and vibrant light for that extra boost. "Concentrate" enables you to focus and get your work done with finely tuned bright white light. "Read" gives the optimal warm white light that does not strain your eyes - perfect for that good read. "Relax" helps you to unwind with a soft glow of warm white light. -
All shades of white light
Set the right ambience for any moment with a range of beautiful, natural white LED light. Use the app on your smart device to set any shade of white light, from cool energizing daylight (6500K) to relaxing warm white light (2200K). -
Smooth wireless dimming
Adjust the brightness of your Philips Hue lights easy and seamlessly via your smart device. No need to rewire your home or install a wall dimmer. -
3D texture for sparkling light
Hue Phoenix has a 3D texture that enhances its looks and gives a pleasant diffusion of light. The surface of the lamp is covered with a hexagonal pattern that captures and reflects light, which creates a sparkling effect. The effect changes depending on your viewing angle, making Hue Phoenix a dynamic and eye-catching piece of decoration in your home, even when the lights are off. -
Control from your smart device
Connect this Philips Hue lamp with the Hue bridge and discover the full range of lighting possibilities. Control the Hue lamp wirelessly from any iOS or Android device via the Philips Hue app or any third party app developed for Hue. Set timers, notifications, alarms, geofencing for soft security, and sync to your entertainment system for the full Hue experience. -
Timers and light notifications
Set your Philips Hue lights to notify you of incoming calls, messages, social media updates, appointments, the weather and other relevant communications received through your smart device. Through the IFTTT platform, you can set different behaviors for your lighting. Hue's ambient light notifications are a pleasant way to keep you informed and connected. -
Safety and security at home
Make it look like you are at home even when you are away. Set scheduled alarms or use timers to turn your lights on and off at fixed or random times. With online access, you can also control your home lighting directly via the app on your smart device. Enable geofencing in the app and your lights will automatically turn on or off when you enter or leave the house. Convenient and peace of mind - wherever you are.
- Philips Hue Phoenix - recessed lamp - LED - 5 W - warm white light - 2200-6500 K - white
- Product Type
- Recessed lamp
- Light Source Type
- LED
- Dimmer
- White
- Wattage
- 5 W
- Wattage Equivalent
- 31 W
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2200-6500 K
- Number of LEDs
- 1
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Product Type
- Recessed lamp
- Supported Light Bulb Wattage
- 5.5 W
- Dimmer
- Double insulated, Android compatible, iOS compatible, Wi-Fi controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 5 W
- 31 W
- Warm white light
- 2200-6500 K
- Number of LEDs
- 1
- Lifetime
- 20000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
- Product Material
- Metal, synthetics
- Body Colour
- White
- IP20
- Warranty
- 2 years
- 14 cm
- Diameter
- 8.4 cm
- 296 g
