Philips Hue Outdoor - Motion Sensor
Quicklinx: FV7LWS00 Mfr#: 929001975801
Marketing description is not available.
  • A warm welcome, every day
    Experience the comfort of your lights turning on automatically when you get home. Unpack your car, enter your house, all with the convenience of your outdoor lights. Having friends over? Welcome them with lights gently switching on as they approach the front door.
  • Scare away uninvited guests
    Thanks to the large view angle and detection range the outdoor sensor will spot any movement near your home. It can directly turn on your outdoor lights to expose uninvited guests in the light. You can set the indoor lights to turn on so it looks like you're home, even when you're not.
  • Automatically turn on lights
    The outdoor sensor turns on your Philips Hue lights automatically when somebody passes by, outdoor and indoor. By connecting the sensor to your bridge via the Philips Hue app, you can choose which lights go on, even inside your house. Also choose the scene or light setting that should be triggered. The integrated dusk-to-dawn sensor ensures your lights only switch on when it is actually dark outside helping you to conserve energy.
  • Requires a Philips Hue bridge
    Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
  • Resistant to all weather
    This Philips Hue outdoor sensor is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. This lamp is designed with IP54: it is protected against water splashed from any direction. The product will withstand heavy rainfall and other weather conditions.
  • Installed in a minute
    The outdoor sensor is easy to mount and fully wireless. So, you don't need an electrician to have it installed. Just unpack the sensor, set it up through the app and install it wherever you like. Configuring the sensor and setting the daylight and motion sensitivity is also done via the Philips Hue app.
Philips Hue - motion sensor
Motion sensor
Environment
Outdoor
Functions
Light control, motion detection, turn electronics on/off
Power Source
Internet of Things (IoT) Platform
Hue, Apple HomeKit
Intelligent Assistant
Alexa, Google Assistant, Cortana
Wireless
7.6 cm x 5.6 cm x 7.6 cm
Motion sensor
Environment
Outdoor
Functions
Power Source
Wireless
Android 7.0 (Nougat) or later, Apple iOS 11 or later
Weather-resistant, wall mountable
Hub Compatibility
Philips Hue Bridge
Platform
Hue, Apple HomeKit
2 AA batteries
Warranty
IP54
7.6 cm
5.6 cm
7.6 cm
145 g
Shipping Width
17 cm
Shipping Depth
7.5 cm
Shipping Height
16.5 cm
Shipping Weight
305 g
