With the Philips Hue White Ambiance spot, you can enjoy natural white light that helps you to wake up, energize, concentrate, read and relax. A high-quality spot, built to last with attention to detail.
Full control from a smart device with the Hue bridge
Connect your Philips Hue lights with the bridge to unlock the endless possibilities of the system. -
Create your ambiance with warm white to cool daylight
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice cool daylight of winter. -
Wake up and go to sleep naturally
Philips Hue will help to get you out of bed the way you like it, helping you start your day feeling refreshed. The light's brightness increases gradually, mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. -
Smart control, home and away
With the Philips Hue iOS and Android apps you can control your lights remotely, from wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late. -
Set timers for your convenience
Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually during the night, so you never have to worry whether you've left any lights on.
- Philips Hue White ambiance Milliskin - recessed spot light - LED spot light bulb - GU10 - 5.7 W - warm to cool white light - 2200-6500 K - white (pack of 3)
- Product Type
- Recessed spot light
- Recommended For
- Kitchen, living room, bedroom, workspace
- Light Source Type
- Packaged Quantity
- 3 (specifications are for single item)
- Supported Light Bulbs Qty
- 1
- Dimmer
- White
- Socket Type
- GU10
- Wattage
- 5.7 W
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Hue
- Communications Technology
- Bluetooth
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Recommended For
- 1
- Position Adjustments
- Swivel head
- Dimmer
- Double insulated, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled, voice control
Light Source
- Socket Type
- GU10
- Wattage
- 5.7 W
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Lifetime
- 15000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Bluetooth
- Product Material
- Synthetics
- Body Colour
- White
- Package
- Box
- IP20
- Warranty
- 2 years
- Diameter
- 9 cm
- 198 g
- Dimensions & Weight Details
- Hole cut-out - width: 7 cm x depth: 10 cm
- Shipping Dimensions (WxDxH) / Weight
- 21.9 cm x 10 cm x 20.9 cm / 856 g
