Philips Hue Milliskin Recessed Spotlight - Aluminium 3x5W
Quicklinx: GVYVWS00 Mfr#: 929003045101
With the Philips Hue White Ambiance spot, you can enjoy natural white light that helps you to wake up, energize, concentrate, read and relax. A high-quality spot, built to last with attention to detail.
  • Full control from a smart device with the Hue bridge
    Connect your Philips Hue lights with the bridge to unlock the endless possibilities of the system.
  • Create your ambiance with warm white to cool daylight
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice cool daylight of winter.
  • Wake up and go to sleep naturally
    Philips Hue will help to get you out of bed the way you like it, helping you start your day feeling refreshed. The light's brightness increases gradually, mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Smart control, home and away
    With the Philips Hue iOS and Android apps you can control your lights remotely, from wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late.
  • Set timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually during the night, so you never have to worry whether you've left any lights on.
Philips Hue White ambiance Milliskin - recessed spot light - LED spot light bulb - GU10 - 2200-6500 K - silver (pack of 3)
Recessed spot light
Light Source Type
LED spot light bulb
Packaged Quantity
3 (specifications are for single item)
Supported Light Bulbs Qty
1
Dimmer
Silver
Socket Type
GU10
Colour Temperature
2200-6500 K
Luminous Power
350 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue
Communications Technology
Bluetooth
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Recessed spot light
1
Dimmer
Double insulated, app-controlled, voice control
Light Source
LED spot light bulb
Socket Type
GU10
Colour Temperature
2200-6500 K
Luminous Power
350 lumens
Lifetime
15000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth
Product Material
Synthetics
Body Colour
Silver
Package
Box
IP20
Warranty
2 years
Diameter
9 cm
198 g
Dimensions & Weight Details
Hole cut-out - width: 7 cm x depth: 10 cm
21.9 cm x 20.9 cm x 10 cm / 856 g
