Enhance your outdoor space and create the right atmosphere for any occasion with Lily spot lights.
Weather-proof design
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. -
Set timers for your convenience
Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine. -
High-quality aluminum and superior synthetics
The products are made specifically for outdoor use. Quality materials are used to ensure better performance in the outdoor conditions as well as smart use of materials to optimize radio frequency.
- Philips Hue White and Color Ambiance Lily - garden spot light set - LED x 3 - 16 million colours - 2000-6500 K - black
- Product Type
- Garden spot light set
- Recommended For
- Garden, patio
- Light Source Type
- 3 x LED
- Dimmer
- Cable Length
- 50 cm
- Black
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Intelligent Assistant
- Siri, Google Assistant, Alexa
- Platform
- Apple HomeKit, Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Recommended For
- Garden, patio
- Dimmer
- Cable Length
- 50 cm
- Waterproof
- Weatherproof, outdoor usage, protection class III, dustproof, app-controlled, voice control, LowVolt system
Light Source
- 3 x LED
- Built-in LED Lamp
- G
- 2000-6500 K
- Colour Rendering Index
- 80
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Product Material
- Aluminium, synthetics
- Body Colour
- Black
- Included Accessories
- Mounting kit, power supply
- IP65
- Warranty
- 2 years
- Dimensions & Weight Details
- Spotlight - width: 7 cm x depth: 8.4 cm x height: 19.4 cm - 430 g , Spotlight - width: 11.2 cm x depth: 11.2 cm x height: 19 cm - 1.4 kg
