Philips Hue LightStrips Plus 2m UK/EU *V2
Quicklinx: CHZ4WS00 Mfr#: 915005106702
Select:
  • 2m
Colour your world with light
The Philips friends of hue LightStrips starter kit lets you create ideal mood lighting at home with your smartphone or devices. Create that extra dimension on architectural features or simply behind objects. Bend, shape or flex — it's your choice.
Wireless connectivity
  • Control from your iOS and Android smart devices.
  • Always up to date.
  • Connect up to 50 bulbs and lamps.
Match your light to the moment
  • Create light settings based on your favourite picture.
  • Use light to help you through your sleeping routine.
  • Enjoy dynamic light effects synced to your moment.
  • Set lights to turn on and off when you're away from home.
Fits with every interior perfectly
  • Ultimate flexibility in placement.
  • Easy to cut. For maximum freedom.
  • Vary your ambience with coloured light.
  • Just the right amount of light.
Create your own light settings
Use your favourite picture to generate the perfect colour scene for special occasions. Go back in time and relive those moments by uploading your own picture and tuning the lights accordingly. Add up to 50 lights to every setting, and recall with a simple tap of the finger.
Light dynamics
The hue ecosystem is fully open for developers. There are an ever-growing number of applications being developed for hue within this community. This has resulted in creative and dynamic lighting schemes opening possibilities of syncing your lights to your favourite music, to get the party kicking.
Philips Hue Lightstrip Plus - light strip - LED
Light strip
Light Bulb
LED
