Get powerful, warm-to-cool white light in the bathroom with the medium Devere ceiling light in white. Brighten the room to apply makeup or get ready for work in the morning - or dim down low for a relaxing soak in the bath.
Set the mood with warm-to-cool white smart lights
Choose from over 50,000 shades of warm-to-cool white light to create the perfect ambiance in your bathroom for each activity and time of day. Use bright, white light each morning to start the day energized and alert, or match your evening wind-down routine with a dim golden glow. -
Optimized light recipes for your daily activities
Use the preset Philips Hue light recipes to fit your mood or activities throughout the day. Start your day with the bright white light of the Energize light recipe, or unwind with the subtle, soft light of Relax. Reading a book in the bath? Set the Read recipe for just the right light. -
Get installation-free dimming straight out of the box
Use the Hue dimmer switch to get instant control over your Philips Hue smart lights. With the touch of a button, anyone in the house can instantly dim or brighten the room, turn lights on and off, or set light scenes. -
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Set up hands-free voice control
Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Control multiple lights in a room or just a single lamp with simple voice commands. -
Unlock full suite of smart light features with Hue Bridge
Add a Hue Bridge (sold separately) to your smart lights to experience the full suite of Philips Hue features. With a Hue Bridge, you can add up to 50 smart lights to control throughout your home. Create routines to automate your entire smart home lighting setup. Control your lights while away from home or add accessories such as motion sensors and smart switches.
- Philips Hue White ambiance Devere M - ceiling lamp - LED - 19.2 W - warm to cool white light - 2200-6500 K - white
- Product Type
- Ceiling lamp
- Recommended For
- Bathroom
- Light Source Type
- LED
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- White
- Wattage
- 19.2 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 1900 - 2450 lumens
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Hue, Nest, Echo
- Communications Technology
- Bluetooth
- Frequency Required
- 50 - 60 Hz
- Product Type
- Ceiling lamp
- Recommended For
- Bathroom
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- Waterproof
- Protection class I, controlled via Bluetooth, app-controlled, power on/off timer, voice control
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 19.2 W
- F
- 2200-6500 K
- Luminous Power
- Lifetime
- 25000 hours
Power Requirements
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue, Nest, Echo
- Compatible Application
- Philips Hue App
- Bluetooth
- Product Material
- Metal, synthetics
- Body Colour
- White
- Included Accessories
- Dimmer switch
- Package
- Box
- IP44
- Warranty
- 2 years / 60 days return
- 8.4 cm
- Diameter
- 38.1 cm
- 2.589 kg
- Shipping Dimensions (WxDxH) / Weight
- 43.7 cm x 45.7 cm x 10 cm / 3.389 kg
