Philips Hue Daylo Wall Lantern
Quicklinx: GVYCWS00 Mfr#: 915005843301
Bring a ring of light to your outdoors with the Daylo wall light in black, a round outdoor fixture offering 16 million colors. Get a soft, diffused outward light effect, as well as a subtle backlight behind the fixture.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use. Philips uses the highest-quality materials to ensure the best performance in outdoor conditions, as well as smart use of materials to optimize radio frequency.
  • Requires a Philips Hue bridge
    Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
  • Control it your way
    Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice.
  • Paint your outdoors with 16 million colors
    With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out. Use the Hue app to save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Decorate for the holidays with light
    Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween.
  • Come home to a house filled with light
    Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
Philips Hue White and Color Ambiance Daylo - wall lamp - LED - 15 W - 16 million colours - 2000-6500 K - inox
Wall lamp
Light Source Type
LED
Dimmer
Inox
Wattage
15 W
Wattage Equivalent
80 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1050 lumens
Number of LEDs
1
Intelligent Assistant
Siri, Google Assistant, Alexa
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Wall lamp
Dimmer
Waterproof
Double insulated, weatherproof, wall mountable, outdoor usage, remote controlled, dustproof, diffused light effect, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
15 W
Wattage Equivalent
80 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1050 lumens
Number of LEDs
1
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Product Material
Stainless steel, synthetics
Body Colour
Inox
Package
Box
IP44
Warranty
2 years
220 mm
220 mm
76 mm
778 g
26.7 cm x 9.5 cm x 28.4 cm / 1.065 kg
