This stylish Philips Hue LED semi-flush ceiling light lets you easily choose and change your home's lighting design. Once the light is connected to your home wireless network via the Philips Hue bridge (not included) you can take complete control of your home lighting from your smartphone or tablet. Featuring options for both scene-setting mood lighting and warm white task lighting.
What's in the box?
- 1x Philips Hue Beyond Ceiling Light
Safety and security at home
Make it look like you are at home even when you are away. Set scheduled alarms or use timers to turn your lights on and off at fixed or random times. With online access, you can also control your home lighting directly via the app on your smart device. Enable geofencing in the app and your lights will automatically turn on or off when you enter or leave the house. Convenient and peace of mind - wherever you are. -
Double the hue experience
Read and work in harmony with how you feel, whether relaxed, energized or sociable - all through the power of light. Hue Beyond has two independent light sources - an uplight and a downlight - so you can create an endless mix of colors to match your mood and set functional lighting for your work or task, both at the same time. -
Get the best functional light
Get the best functional light for whatever you do. Read, write or get your work done with the high quality LED light. -
Make an endless mix of colors
Choose for one color, or combine different colors - thanks to the two independent light sources - to create the perfect atmosphere to match your mood, whether it's to relax, energize or explore. -
Expand your hue ecosystem
You can connect up to 50 bulbs or lamps to the Philips Hue bridge. Simply begin with any of the available starter kits and start adding Philips Hue products.
- Philips Hue Beyond - ceiling lamp - LED - 18 W - warm white light - white
- Product Type
- Ceiling lamp
- Light Source Type
- LED
- Dimmer
- White
- Wattage
- 18 W
- Wattage Equivalent
- 112 W
- Colour of Illumination
- Warm white light
- Beam Angle
- 120 degree(s)
- Number of LEDs
- 4
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Product Type
- Ceiling lamp
- Compatible Light Bulb Energy Class
- A, A++, A+
- Dimmer
- Android compatible, iOS compatible, ZigBee Light Link, Wi-Fi controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 18 W
- 112 W
- Warm white light
- Beam Angle
- 120 degree(s)
- Number of LEDs
- 4
- Lifetime
- 15000 hours
- PowerLED
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
- Product Material
- Metal, glass
- Body Colour
- White
- IP20
- Warranty
- 2 years
- 20.8 cm
- Diameter
- 45 cm
- 4.44 kg
