The extra-large Enrave ceiling light in white illuminates wide areas, useful in combination living/dining rooms. Its unique effect casts a ring of warm-to-cool white light against the ceiling and a powerful glow downwards.
Set up hands-free voice control
Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Control multiple lights in a room or just a single lamp with simple voice commands. -
Set the right mood with warm-to-cool white light
Choose from over 50,000 shades of warm-to-cool white light to create the perfect ambience in your home for each activity and time of day. Use bright, white light each morning to start the day energized and alert, or match your evening wind-down routine with a dim golden glow. -
Optimized light recipes for your daily activities
Use the preset Philips Hue light recipes to fit your mood or activities throughout the day. Start your day with the bright white light of the Energize light recipe, or unwind with the subtle, soft light of Relax. Reading a book in the bath? Set the Read recipe for just the right light. -
Control lights instantly
Get instant control over your Philips Hue smart lights with the Hue dimmer switch. With the touch of a button, your entire household can instantly dim or brighten the room, turn lights on and off, or set light scenes.
- Philips Hue White ambiance Enrave Extra Large - ceiling lamp - LED - 48 W - warm to cool white light - 2200-6500 K - white
- Product Type
- Ceiling lamp
- Recommended For
- Living room, bedroom, dining room
- Light Source Type
- LED
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- White
- Wattage
- 48 W
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 6100 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Communications Technology
- Bluetooth
- Frequency Required
- 50 - 60 Hz
- Product Type
- Ceiling lamp
- Recommended For
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- Protection class I, remote controlled, app-controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 48 W
- 2200-6500 K
- Luminous Power
- 6100 lumens
- Lifetime
- 25000 hours
Power Requirements
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Compatible Application
- Philips Hue App
- Bluetooth
- Voice Controlled
- Indirect
- Product Material
- Metal, synthetics
- Body Colour
- White
- Included Accessories
- Dimmer switch
- IP20
- Warranty
- 2 years / 30 days return
- 8.4 cm
- Diameter
- 55.1 cm
- 4.55 kg
- Shipping Dimensions (WxDxH) / Weight
- 60 cm x 62.5 cm x 10 cm / 5.72 kg
