Brand
Philips E-line 288E2A - LED monitor - 28" - 3840 x 2160 4K @ 60 Hz -
Quicklinx: G95WWS00 Mfr#: 288E2A/00
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort
£216.34 ex VAT
£259.60 inc VAT
The Philips E Line monitor features stunning visuals and stylish design for your workspace. Ultra-clear 4K UHD and Ultra Wide-Color deliver ultimate clarity and life-like visuals. MultiView meets the need for usability and productivity.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
Ultra Wide-Color wider range of colours for a vivid picture
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
Effortlessly smooth gameplay with AMD FreeSync™ technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync™ technology, smooth, quick refresh and ultra-fast response time.
SmartImage game mode optimised for gamers
The new Philips gaming display has quick-access OSD fine-tuned for gamers, offering you multiple options. "FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas. "Racing" mode adapts the display with the fastest response time and high colour, along with image adjustments. "RTS" mode (Real-time strategy) has a special SmartFrame mode that enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customised settings based on different games, ensuring best performance.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Cable management reduces cable clutter for a neat workspace
Cable management is an intimate design that maintains a tidy workspace by organising the cables and wires required for the operation of a display device.
EasySelect menu toggle key for quick on-screen menu access
The discreetly placed EasySelect Menu Toggle Key allows you to make quick and easy adjustments to monitor settings in the On-Screen Display menu.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
IPS LED wide view technology for image and colour accuracy
IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
1.07 billion colours for stunning colour and the finest gradation
This display delivers outstanding colour depth with 1.07 billion colours and the finest gradation for recreating smooth, precise and vivid images. Enjoy accurate and true-to-life visuals whether gaming, watching videos or working on colour-critical work with graphics applications.
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Built-in stereo speakers
  • SmartContrast
  • SmartImage Game mode
    The new Philips gaming display has quick-access OSD fine-tuned for gamers, offering you multiple options."FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas."Racing" mode adapts the display with the fastest response time and high colour, along with image adjustments."RTS" mode (Real-time strategy) has a special SmartFrame mode that enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customised settings based on different games, ensuring best performance.
  • UltraClear 4K UHD Resolution
  • MultiView technology
  • Ultra-smooth gaming
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync technology, smooth, quick refresh and ultra-fast response time.
  • Ultra Wide-Color Technology
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • Cable management
  • EasySelect Menu Toggle Key
Philips E-line 288E2A - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class G
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
31.4 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
Colour Gamut
106.9% NTSC, 119.7% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
63.7 cm x 22.4 cm x 48 cm
5.59 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, TUV, VCCI, BSMI, CB, DDC/CI, RoHS, ISO 9241-307, MEPS, TUV Bauart, EPA, CU-EAC
Display Type
Energy Class
Class G
62 kWh
Diagonal Size
28"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
40 - 60 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, Lead-free, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, Adaptive-Sync technology, Mega DFC, EasyRead, sRGB Mode, Picture-in-Picture, Delta E<2 calibration
Black texture
63.7 cm x 22.4 cm x 48 cm - with stand
5.59 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DisplayPort , 2 x HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31.4 W
31.4 kWh/1000h
Power Consumption (Typical)
27.6 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 63.7 cm - depth: 22.4 cm - height: 48 cm - weight: 5.59 kg , Without stand - width: 63.7 cm - depth: 4.1 cm - height: 36.7 cm - weight: 4.28 kg
Shipping Width
73 cm
Shipping Depth
15.9 cm
Shipping Height
52.2 cm
Shipping Weight
8.25 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
Diagonal Size: 28in
Response Time: 4ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Philips
