The Philips PowerSensor LED display using 65% post consumer recycled plastics and PVC, BFR free housing is ideal for Eco-friendly productivity.
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for Eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
- Philips Brilliance B-line 220B4LPCS - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- USB Hub
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Textured silver, textured black with silver stand
- 50.4 cm x 22.7 cm x 50.9 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, TCO Displays 5.2
- 3 years warranty
- Display Type
- Diagonal Size
- 22"
- Built-in Devices
- USB Hub
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, Smart Ergo base
- 50.4 cm x 22.7 cm x 50.9 cm - with stand
- 5.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D , Audio line-in , 2 x USB 2.0 , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 15.8 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7
- Dimensions & Weight Details
- With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.03 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.28 |
C2G 2-Port USB 2.0 Manual Switch | In Stock | £16.49 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £11.53 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £25.75 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £15.20 |
