Philips Brilliance 272C4QPJKAB - 27" - 2560 x 1440 6MS 2xHDMI DVI-D speakers LED Monitor
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 8M12WS00 Mfr#: 272C4QPJKAB/00
This Philips 27" display will amaze you with its Crystalclear Quad HD 2560 x 1440 images and brilliant colors. MultiView allows active dual connect and view. Its 2-magepixel webcam enables you to socialize.
  • PLS Quad HD
    This professional Philips display uses the latest PLS Quad HD panel giving you ultra high-res brilliant wide angle images with 2560 x 1440 pixel resolution. With excellent 8-bit color depth combined with 109 ppi density, you can now enjoy professional true color sRGB images compared to limited 6-bit color depth displays with 82 ppi density. Its higher brightness and lower power consumption compared to conventional wide view angle displays ensure you always have brilliant performance, while saving energy too.
  • Crystalclear images
    These latest Philips screens deliver Crystalcl ear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images.
  • PowerSensor
    PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
  • Socialize with webcam
    Embedded 2-megapixel webcam with superb, bright and crisp images enables you to socialize with your family and friends. Its sensitive microphone ensures that your voice carries through clearly. You can hear clear audio either from its built-in stereo speakers, or attach your own headphones for private conversations. This simple built-in solution ensures you don't have to get in a tangle anymore with installing a camera and positioning microphones.
  • MultiView technology
    With the ultra high resolution Philips MultiView display you can now experience a world of connectivity in comfort whether at the office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and Notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feeds from your set-top box on the right-hand side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your latest blog.
  • Display port with daisy chain
    This Philips display employs Display port 1.2a Multi Stream Transport (MST) technology with HBR2, which doubles the data throughput to 21.6 Gbps. This enables it to daisy chain multiple monitors, thereby dramatically increasing your efficiency. This daisy chain, multi-monitor capability makes this Philips display especially suitable for use in Finance, Banking, control rooms and other similar environments. To make use of this feature, your PC Graphics Card must be certified to DP1.2 with the MST option.
  • SmartConnect
    With a plethora of connectivity, these Philips displays come equipped with multi connections like Dual link DVI, Display Port, universal HDMI connector or optional Thunderbolt, enabling you to enjoy high resolution uncompressed video and audio content. USB 3.0 option ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and optimizes your display performance. This user-friendly interface allows you to select various modes, like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartKolor
    SmartKolor is a sophisticated color extension technology that is able to enhance the visual color range of the display. By boosting the RGB gain level of the display, you can achieve rich, vibrant images to experience outstanding photos and videos.
Philips Brilliance 272C4QPJKAB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
2.0 megapixel camera
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
6 ms (grey-to-grey), 12 ms (typical)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
Textured black with black stand
63.9 cm x 19.7 cm x 49.5 cm
6.3 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
3-year warranty
Display Type
Energy Class
Class B
62 kWh
Diagonal Size
27"
Built-in Devices
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Picture in picture, picture by picture, Sync on Green, sRGB colour management, PowerSensor, SmartResponse, MultiView, Crystal Clear, SmartContrast, SmartImage, SmartKolor, SmartTxt
63.9 cm x 19.7 cm x 49.5 cm - with stand
6.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (dual link) (HDCP) , Audio line-in , Headphones , DisplayPort , 2 x HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
42 W
Power Consumption (Typical)
38 Watt
Power Consumption Stand by
0.4 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 19.7 cm - height: 49.5 cm - weight: 6.3 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.6 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
