With features like SmartImage, front stereo audio, USB port and ergo base, the energy efficient 19B1 business display enhances your productivity.
Built in stereo audio
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design. -
70mm height adjustment
The Compact Ergo Base is a 'people friendly' Philips monitor base that tilts, swivels and is height adjustable so each user can position the monitor for maximum viewing comfort and efficiency. -
Screen tilt and swivel
Screen tilt and swivel is a mechanism built into the base permits the monitor to swivel and tilt backward or forward. -
SmartImage
SmartImage is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button. -
SmartControl II
SmartControl II is monitor-based software with an easy to use, on screen graphic interface that guides you through fine tuning resolution, color calibration and other display settings including brightness, contrast, clock and phase, position, RGB, white point and - on models with onboard speakers - volume adjustments. -
TrueVision
TrueVision is industry leading, proprietary Philips testing and algorithm technology for monitor adjustment and fine tuning, an extensive process that ensures ultimate display performance in compliance with a standard four times more stringent than Microsoft's Vista requirements from each and every monitor that leaves the factory - not just a few review samples. Only Philips goes to these lengths to deliver this exacting level of color accuracy and display quality in every new monitor. -
EPEAT Silver
The EPEAT (Electronic Product Environmental Assessment Tool) program helps purchasers evaluate, compare and select computer products like Monitors based on 51 environmental criteria supported by US EPA. EPEAT certification ensures reduction in use of toxic materials and hazardous waste and also ensures compliance with Energy Star. All Philips monitors are EPEAT-registered with Silver tier, ensuring protection for human health and environment, while being more energy efficient ensuring low emissions of climate changing green house gases. -
Eco-friendly materials
With sustainability as a strategic driver of its business. Lead-free materials are used across the range. All body plastic parts, metal chassis parts and packing material uses 100% recyclable material. 50% reduction in mercury content in lamps has been achieved. Philips strictly adheres to RoHS standards which ensure that all hazardous material is removed, and only environmentally friendly material is used. -
Sustainable Eco-friendly solution
Energy Star for energy efficiency and low power consumption. Eco-friendly materials meet major international standards. EPEAT Silver ensures lower impact on environment. -
Outstanding display performance
SmartImage: optimized user friendly display experience. SmartContrast: for incredible rich black details. TrueVision: laboratory quality display performance. -
Ergonomic design
70mm height is adjustment for ideal sitting position. Tilt and swivel adjustment for an ideal viewing angle. -
Great convenience
Built in stereo audio is for multimedia experience. USB port enhances multimedia experience. Hassle-free display performance tuning with SmartControl II.
- Philips Brilliance 19B1CS - LCD monitor - 19"
- LCD monitor - 19"
- Stereo speakers, USB Hub
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 800:1 / 25000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 44.2 cm x 20 cm x 40.4 cm
- 4.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 19"
- Built-in Devices
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Controls & Adjustments
- Brightness, contrast
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Chinese
- Sync on Green, sRGB colour management, HDCP, Lead-free, SmartContrast, SmartImage, TrueVision
- Black, silver
- 4.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , Audio line-in/out , USB 2.0
Mechanical
- Tilt Angle
- 25
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 50,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Philips SmartControl II
- OS Required
- Microsoft Windows 98, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
