With features like SmartImage, SmartContrast, SmartControl and TrueVision, the energy efficient 17S1 business display increases your productivity.
SmartImage
SmartImage is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button. -
Adjustable tilt
Adjustable tilt is backward and forward movement of a screen on its base to achieve custom positioning for an ideal viewing angle and more comfort for people who spend long hours working on the computer. -
Eco-friendly materials
With sustainability as a strategic driver of its business, Philips is committed to use eco-friendly materials across its product range. Lead-free materials are used across the range. All body plastic parts, metal chassis parts and packing material uses 100% recyclable material. 50% reduction in mercury content in lamps has been achieved. They strictly adhere to RoHs standards which ensure that all hazardous material is removed, and only environmentally friendly material is used. -
Energy Star 5.0
Energy Star is a US EPA sponsored energy efficiency program also adopted by many other countries. Energy Star certification ensures that you are buying a product which meets the latest power efficiency standards which operates with maximum power efficiency at all operational levels. Philips monitors are certified for Energy Star 5.0 specifications and meet or exceed the standard. For example, in sleep mode Energy Star 5.0 requires less than 1watt power consumption, whereas Philips monitors consume less than 0.5watts.
- Philips Brilliance 17S1SB - LCD monitor - 17"
- LCD monitor - 17"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 800:1 / 25000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black texture
- 38.9 cm x 17.9 cm x 36.7 cm
- 3.45 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 17"
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Controls & Adjustments
- Brightness
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Sync on Green, HDCP, SmartContrast, SmartImage, TrueVision
- Black texture
- 3.45 kg
- VGA , DVI-D
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- MTBF
- 50,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Philips SmartControl II
- OS Required
- Microsoft Windows 98, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
