Philips B Line 243B9H 24" LED 1920x1080 4ms HDMI VGA USB
Quicklinx: GGMTWS00 Mfr#: 243B9H/00
The Philips B line monitor with USB-C replaces cable clutter. View Full HD image and recharge your laptop, all at the same time with a single USB-C cable. A secure pop-up webcam with Windows Hello offers a personalized, greater security.
  • Power and re-charge compatible notebook from the monitor
    This monitor features a built-in USB-C connector that meets USB Power Delivery standard. With intelligent and flexible power management, you can now power up and/or re-charge your compatible* Notebook directly from the Monitor using a single USB-C cable.
  • PowerSensor saves up to 80% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
  • IPS technology for full colors and wide viewing angles
    IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • Securely sign in with pop-up webcam with Windows Hello
    Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
  • SmartErgoBase enables people-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional.
  • Built-in stereo speakers for multimedia
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Connect your notebook with one USB-C cable
    This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high resolution video and transfer data at a super-speed, while powering up and re-charging your compatible device at the same time.
  • Designed to meet environmental standards
    Designed for sustainability, and reduced operating costs, this monitor meets environmental standards. Such as: ENERGY STAR, EPEAT, TCO Certified.
Philips B Line 243B9H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/448856
Energy Class
Class D
Power Consumption (On mode)
14.8 W
Microphone, 2.0 megapixel camera, USB 3.2/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Built-in Webcam
2 Megapixel - 1920 x 1080
Display Position Adjustments
Screen Coating
Haze 25%, anti-glare 3H hardness
Voltage
Black texture
54.1 cm x 21.6 cm x 52.2 cm
5.44 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, CU-EAC, EAEU RoHS
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, sRGB Mode, SmartControl
Black texture
54.1 cm x 21.6 cm x 52.2 cm - with stand
5.44 kg
Built-in Webcam
Sensor Resolution
2 Megapixel
Max Video Resolution
1920 x 1080
LED indicator, Windows Hello compatible
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort 1.2 (HDCP 1.4) , HDMI (HDCP 1.4) , USB-C 3.2 Gen 1 (HDCP 1.4 / power up to 65W) , 2 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C to USB-C / USB-A cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
14.8 W
14.8 kWh/1000h
Power Consumption (Typical)
15.1 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
Dimensions & Weight Details
With stand - width: 54.1 cm - depth: 21.6 cm - height: 52.2 cm - weight: 5.44 kg , Without stand - width: 54.1 cm - depth: 6.3 cm - height: 33.2 cm - weight: 3.83 kg
Shipping Width
60 cm
Shipping Depth
19.8 cm
Shipping Height
47.5 cm
Shipping Weight
7.57 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
