Philips 65HFL2899S 65" Professional Series LED Commercial TV
Quicklinx: FFBVWS00 Mfr#: 65HFL2899S/12
From hotel room to boardroom, give them Philips vibrant picture quality with this budget-friendly standalone professional TV. Benefit from simple, lightning-fast installation and an on-screen welcome page that's easy to program.
  • Instant initial USB cloning
    Provides the ability to easily copy all programming and channel programming settings from one TV into other TV sets in less than a minute. The feature ensures uniformity between TV sets and significantly reduces installation time and costs.
  • Low power consumption
    Philips TVs are designed to minimize power consumption. This will not only reduce environmental impact but also lower operating costs.
  • USB auto playback
    Share the fun. Connect your USB memory stick, digital camera, MP3 player or other multimedia device to the USB port on your TV to enjoy photos, videos and music with the easy to use onscreen content browser.
Philips 65HFL2899S Professional Series - 65" LED-backlit LCD TV - 4K - for hotel / hospitality
LED-backlit LCD TV
Diagonal Class
65"
Commercial Use
Yes - hotel / hospitality
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, prison mode, Joystick Control Lock, menu lock
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
Philips 22AV1407A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A++
Power Consumption (On mode)
82 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
119 kWh
145.7 cm x 6.3 cm x 84.6 cm
23.5 kg
LED-backlit LCD TV
Energy Class
Class A++
82 W
119 kWh
Diagonal Class
65"
Commercial Use
Series
Professional Series
TV Tuner Presence
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Eco mode, hotel mode
Dimensions
Without stand
145.7 cm
6.3 cm
84.6 cm
23.5 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
One touch Play, security lock slot (cable lock sold separately)
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, AVI, MKV, TS, AVC, H.264, HEVC
Supported Audio Formats
MP3, WMA, WAV, AAC
Supported Pictures Formats
BMP, JPG, PNG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Philips 22AV1407A
Battery Form Factor
AAA type
Battery Included Qty
2
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Incredible Surround
Equaliser
Speaker System
2 speakers
Output Power / Total
16 Watt
Balance control, Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC)
Speakers
2 x speaker - 8 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
Digital audio output (optical) - rear , 2 x HDMI - rear , VGA input - rear , Composite video/audio input - rear , Headphones - side , USB 2.0 - side , HDMI - side
Security Slot Type
Kensington security slot
HDCP 2.2
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
Dimensions & Weight Details
Panel without stand - 145.7 cm x 6.3 cm x 84.6 cm x 23.5 kg , Panel with stand - 145.7 cm x 34.7 cm x 90 cm x 24.1 kg
5 °C
45 °C
