Give your guests the viewing experience they deserve. They will enjoy a quicker, more responsive TV with a wealth of dedicated hospitality applications, while you will enjoy easy remote installation and management at your convenience.
CMND & create
You will be able to provide the information you want, when you want. The content management module of CMND, it allows for easy creation and distribution of interactive, branded hotel web pages. Tailor your TV's to give guests information with interesting developments in your hotel, all in real time. -
Integrated IPTV
Save costs and clutter. With this Smart TV you can build your hotel system directly on the TV. Interactive channels, interactive hotel menus and information as well as online ordering systems are all possible without an external box attached to the TV. Next to delivery of the content over coax TV cables, you can also use your Internet network to deliver your TV channels or VOD directly to the TV.
- Philips 55HFL5011T MediaSuite - 55" LED-backlit LCD TV - Full HD - for hotel / hospitality
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 55"
- Commercial Use
- Yes - hotel / hospitality
- Silver
- Platform
- Android TV
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/60p
- Frame Rate & Enhancement Technology
- 200 Hz Perfect Motion Rate
- Video Interface
- Component, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- Mobile High-Definition Link (MHL)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL
- Internet Streaming Services
- HbbTV
- Commercial Features
- Screen welcome message, prison mode, VSecure, mychoice, Serial Xpress Protocol, Bathroom Speaker Output, Double isolation Class II, Independent main speaker mute, IPTV, HTML5 support, SmartInfo, Nurse call system compatible, Multi remote control, CMND management, Playready Smoothstreaming, SecureMedia
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- Incredible Surround
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- USB
- 3 ports
- Included Accessories
- Philips 22AV1505B/12 remote control, 2 AAA batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 67 W
- Power Consumption Stand by
- 0.4 Watt
- Energy Consumption per Year
- 98 kWh
- Dimensions (WxDxH) - without stand
- 123.9 cm x 8 cm x 71.2 cm
- 12.4 kg
- Product Type
- Energy Class
- Class A+
- 67 W
- 98 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- MediaSuite
- Platform
- Android TV
- Operating System
- Android OS 5.1
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- Modes
- Eco mode, hotel mode
- Design
- Flame retardant cabinet
- Protection
- Theft protection
- Dimensions
- Without stand
- 123.9 cm
- 8 cm
- 71.2 cm
- 12.4 kg
- Enclosure Colour
- Silver
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Brightness
- 300 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Plus HD, One touch Play, security lock slot (cable lock sold separately), remote management
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 200 mm
TV Tuner
- Analogue TV Tuner
- PAL
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- MHEG
Video Features
- Analogue Video Input Signals
- NTSC, PAL
- 1080/60p
- Teletext
- Electronic Programme Guide
- Digital EPG, Now & Next
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC
- Supported Audio Formats
- MP3, WMA, WAV, AAC, WMA Pro
- Supported Pictures Formats
- BMP, JPG, GIF, PNG
- USB Port
- USB Ports Qty
- 3
- Configuration
- 8 GB
- 8 GB
Remote Control
- Remote control
- Remote Control Model
- Joystick, low battery alert, battery anti-theft protection, smart phone remote support, AppControl
Audio System
- Digital Audio Format
- Dolby Digital output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control, Dynamic Bass Enhancement
- Speakers
- 2 x main channel speaker - 8 Watt
Network & Internet Multimedia
- Functionality
- Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n
- Connect & Share
- Wi-Fi Miracast, DirectShare
- HbbTV
- Supported Consumer Electronics Control (CEC)
- EasyLink
- Connector Type
- SCART (RGB / Composite) - rear , Speakers output - rear , Component video input - rear , Audio line-in - rear , Audio line-in - rear , Remote control - rear , Digital audio output (optical) - bottom , LAN - bottom , 2 x HDMI - bottom , USB 2.0 - bottom , Headphones - side , 2 x HDMI - side , USB 3.0 - side , USB 2.0 - side
- 2 AAA batteries
- Power Device
- Power supply
- Input Voltage
- 0.4 Watt
- System standby, WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 123.9 cm x 8 cm x 71.2 cm x 12.4 kg , Panel with stand - 123.9 cm x 26.6 cm x 77.8 cm
- 0 °C
- 40 °C
