Philips 49HFL5011T 49" MediaSuite LED Commercial TV
Quicklinx: FFB3WS00 Mfr#: 49HFL5011T/12
  • 1080p
  • DVB-T
Give your guests the viewing experience they deserve. They will enjoy a quicker, more responsive TV with a wealth of dedicated hospitality applications, while you will enjoy easy remote installation and management at your convenience.
  • CMND & Create
    CMND & Create allows you to provide the information you want, when you want. The content management module of CMND, it allows for easy creation and distribution of interactive, branded hotel web pages. Tailor your TV to give guests the most up-to-date information with the latest developments in your hotel, all in real time.
  • CMND & Control
    CMND & Control allows for remote configuration and installation of your TV from a central location, without having to visit any rooms. Update and manage all your displays, with minimal effort, all without having to disturb your guests.
  • Miracast and DirectShare
    Philips TVs give your guests the freedom to enjoy their content on the big TV wirelessly and without hassle. Pictures, movies, music, all can be shared and enjoyed via Miracast and DirectShare.
  • Integrated IPTV
    With Philips Smart TVs you can build your hotel system directly on the TV. Interactive channels, video on demand, interactive hotel menus and information as well as online ordering systems are all possible without an external box attached to the TV. Next to delivery of the content over coax TV cables, you can now also use your Internet network to deliver your TV channels or VOD directly to the TV.
Philips 49HFL5011T MediaSuite - 49" LED-backlit LCD TV - Full HD - for hotel / hospitality
LED-backlit LCD TV - Smart TV
Diagonal Class
49"
Commercial Use
Yes - hotel / hospitality
Silver
Platform
Android TV
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60p
Frame Rate & Enhancement Technology
200 Hz Perfect Motion Rate
Video Interface
Component, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
PC Interface
Mobile High-Definition Link (MHL)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Internet Streaming Services
HbbTV
Commercial Features
Screen welcome message, prison mode, VSecure, mychoice, Serial Xpress Protocol, Bathroom Speaker Output, Double isolation Class II, Independent main speaker mute, IPTV, HTML5 support, SmartInfo, Nurse call system compatible, Multi remote control, CMND management, Playready Smoothstreaming, SecureMedia
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
USB
3 ports
Philips 22AV1505B/12 remote control, 2 AAA batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
Power Consumption (On mode)
50 W
Power Consumption Stand by
0.4 Watt
Energy Consumption per Year
79 kWh
109.9 cm x 7.9 cm x 63.2 cm
14.3 kg
Energy Class
Class A+
50 W
79 kWh
Diagonal Class
49"
Commercial Use
Series
MediaSuite
Platform
Android TV
Operating System
Android OS 5.1
TV Tuner Presence
Video Interface
HDMI Ports Qty
4 ports
PC Interface
Modes
Eco mode, hotel mode
Design
Flame retardant cabinet
Protection
Theft protection
Dimensions
Without stand
109.9 cm
7.9 cm
63.2 cm
14.3 kg
Enclosure Colour
Silver
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Brightness
300 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
Pixel Plus HD, One touch Play, security lock slot (cable lock sold separately), remote management
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 200 mm
TV Tuner
Analogue TV Tuner
PAL
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Analogue Video Input Signals
NTSC, PAL
Input Video Formats
1080/60p
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC
Supported Audio Formats
MP3, WMA, WAV, AAC, WMA Pro
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
3
Configuration
8 GB
8 GB
Remote Control
Remote control
Remote Control Model
Joystick, low battery alert, battery anti-theft protection, smart phone remote support, AppControl
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Incredible Surround
Speaker System
2 speakers
Output Power / Total
16 Watt
Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control, Dynamic Bass Enhancement
Speakers
2 x main channel speaker - 8 Watt
Network & Internet Multimedia
Functionality
Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n
Connect & Share
Wi-Fi Miracast, DirectShare
HbbTV
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
SCART (RGB / Composite) - rear , Speakers output - rear , Component video input - rear , Audio line-in - rear , Audio line-in - rear , Remote control - rear , Digital audio output (optical) - bottom , LAN - bottom , 2 x HDMI - bottom , USB 2.0 - bottom , Headphones - side , 2 x HDMI - side , USB 3.0 - side , USB 2.0 - side
2 AAA batteries
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.4 Watt
System standby, WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 109.9 cm x 7.9 cm x 63.2 cm x 14.3 kg , Panel with stand - 109.9 cm x 25 cm x 69.4 cm
