Philips 43" Curved 32:10 SuperWide Display
Quicklinx: FMQ7WS00 Mfr#: 439P9H/00
Wide open possibilities
Philips 43" curved 32:10 SuperWide display is like two full-size high-performance monitors in one. Productivity-enhancing features like USB-C and pop-up webcam with Windows Hello deliver the performance and convenience you expect.
32:10 SuperWide designed to replace multiscreen setups
32:10 SuperWide 43" screen, with 3840 x 1200 resolution, is designed to replace multiscreen setups for massive wide view. It's like having two 16:10 displays side by side. SuperWide monitors offer the screen area of dual monitors without the complicated setup.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time
  • Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • LowBlue Mode
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Built-in USB-C docking station
    This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time.
  • MultiView technology
    With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Adaptive-Sync technology
  • Compact Ergo Base
    The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
  • DisplayHDR 400
    VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike, other"HDR-compatible" screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and peak brightness up to 400 nits, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
  • MultiClient Integrated KVM
    With the MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse setup. A convenient button allows you to quickly switch between sources. Handy with setups that require dual PC computing power or sharing one large monitor to show two different PCs.
  • Windows Hello pop-up webcam
    Phillips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
  • 32:10 SuperWide
Philips P-line 439P9H - LED monitor - curved - 43.4" - HDR
LED-backlit LCD monitor - 43.4"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/398393
Energy Class
Class G
Energy Consumption per Year
100 kWh
Power Consumption (On mode)
47 W
Curved Screen
Microphone, KVM Switch, 2.0 megapixel camera, USB 3.2 Gen 1 hub, USB PD 90 watt
Panel Type
VA
Aspect Ratio
32:10
Native Resolution
3840 x 1200 at 100 Hz
Pixel Pitch
0.274 mm
Brightness
450 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
105% NTSC (CIE 1976), 123% sRGB (CIE 1931), 91% Adobe RGB, 95% DCI-P3 wide, 99% BT.709
Input Connectors
HDMI, 2xDisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 2H Hard Coating, Haze 25%
Voltage
Black texture
105.8 cm x 30.3 cm x 46 cm
14.37 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, CU-EAC, BFR-free, DisplayPort 1.4, HDCP 2.2, HDCP 1.4, PVC-free
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
100 kWh
Diagonal Size
43.4"
Viewable Size
43"
Curved Screen
Yes (1800R)
Built-in Devices
USB Power Delivery
90 watt
Panel Type
VA
Aspect Ratio
32:10
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
450 cd/m²
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 150 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, MultiView, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, Adaptive-Sync technology, EasyRead, Windows 10 Hello
Black texture
105.8 cm x 30.3 cm x 46 cm - with stand
14.37 kg
Audio
Speakers - stereo
Output Power / Channel
5 watt
Input
Microphone
2 x DisplayPort (HDCP) , HDMI (HDCP) , USB-C with Power Delivery (power up to 90W) , USB-C 3.2 Gen 1 upstream , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Headphones , Network (RJ-45)
Mechanical
Tilt Angle
-5/+10
Swivel Angle
40
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), DisplayPort Alt Mode
HDMI cable , DisplayPort cable , USB-C cable , USB-C to USB-A cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
47 W
47 kWh/1000h
Power Consumption HDR (On mode)
79 kWh/1000h
Power Consumption (Typical)
41.8 watt
Power Consumption Stand by
0.4 watt
Power Consumption (Off Mode)
0 watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand - width: 105.8 cm - depth: 30.3 cm - height: 46 cm - weight: 14.37 kg , Without stand - width: 105.8 cm - depth: 13.7 cm - height: 36.1 cm - weight: 10.34 kg
Shipping Width
115 cm
Shipping Depth
35 cm
Shipping Height
52.5 cm
Shipping Weight
20.19 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
