Philips 323E7QDAB 31.5" 1920x1080 5ms VGA DVI HDMI Monitor
WAS £225.39!
Price Drop
Quicklinx: C9Z0WS00 Mfr#: 323E7QDAB/00
IPS LED wide view technology for image and colour accuracy
IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
SmartContrast for deep black level details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
EasySelect menu toggle key for quick on-screen menu access
The discreetly placed EasySelect Menu Toggle Key allows you to make quick and easy adjustments to monitor settings in the On-Screen Display menu.
HDMI-ready for Full HD entertainment
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
SmartImage Lite for easy optimised image settings
SmartImage Lite is an exclusive, leading edge Philips technology that analyses the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, colour saturation and sharpness of images and videos for ultimate display performance - all in real time with the press of a single button.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
Philips E-line 323E7QDAB - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.364 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Glossy black
70.3 cm x 21.6 cm x 52.2 cm
6.91 kg
Plug and Play, FCC Class B certified, TUV, SASO, DDC/CI, RoHS, Lead-Free, ETL, ISO 9241-307, WEEE, KUCAS, CU
Display Type
Energy Class
Class A
52 kWh
Diagonal Size
32"
Viewable Size
31.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.364 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage Lite, SmartContrast, Flicker Free technology, Mercury free, Wide Viewing Angle, EasySelect Menu Toggle Key
Glossy black
70.3 cm x 21.6 cm x 52.2 cm - with stand
6.91 kg
Audio
Speakers - stereo
Output Power / Channel
5 watt
VGA , DVI-D (HDCP) , HDMI (HDCP) , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+10
VESA Mounting Interface
100 x 100 mm
VGA cable , Audio cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
36 W
Power Consumption (Typical)
45.7 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 70.3 cm - depth: 21.6 cm - height: 52.2 cm - weight: 6.9 kg , Without stand - width: 73 cm - depth: 6.4 cm - height: 43.1 cm - weight: 5.89 kg
Shipping Width
79 cm
Shipping Depth
13.9 cm
Shipping Height
62.5 cm
Shipping Weight
8.85 kg
20 - 80%
C9Z0 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.15
