Philips 278E1A/00 27 INCH IPS 4K MM HDMI DP
Quicklinx: GWFVWS00 Mfr#: 278E1A/00
The 27" E Line monitor features stunning visuals and elegant design for a stylish enhancement to your workspace. Ultra-clear 4K UHD with wide view delivers same the ultimate clarity and lifelike visuals from any front-angle view.
  • Cable management reduces cable clutter for a neat workspace
    For a cleaner workspace, this monitor features an elegant solution for cable management. No need to bundle cables with extra ties. An elongated slot provides hidden storage for cables. It conceals cables and looks great in most environments, especially for a small space or a desk facing a wall or a window. This design cleans up messy cables for a more organised desk.
  • Eco-friendly materials meet major international standards
    "Philips is committed to use sustainable, eco-friendly materials across its monitor range. All body plastic parts, metal chassis parts and packing materials use 100% recyclable materials. In some selected models we utilize upto 65% post consumer recycled plastics. Strict adherence to RoHS standards ensure substantial reduction or elimination of toxic substances like Lead, for example. Mercury content in monitors with CCFL backlight has been reduced significantly, while eliminated in monitors with LED backlight completely.
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • Less eye fatigue with Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • HDMI ensures universal digital connectivity
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality digital video and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • IPS LED wide view technology for image and colour accuracy
    IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • SmartContrast for rich black details
    SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • SmartImage game mode optimised for gamers
    The new Philips gaming display has quick-access OSD fine-tuned for gamers, offering you multiple options."FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas."Racing" mode adapts the display with the fastest response time and high colour, along with image adjustments."RTS" mode (Real-time strategy) has a special SmartFrame mode that enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customised settings based on different games, ensuring best performance.
  • UltraClear 4K UHD (3840x2160) resolution for precision
    These Philips displays utilize high performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
Philips E-line 278E1A - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/388180
Energy Class
Class F
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
26.1 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.155 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
109% sRGB, 91% NTSC
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Glossy black
61.3 cm x 19.2 cm x 46.1 cm
4.78 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, ICES-003, CCC, DDC/CI, RoHS, ISO 9241-307, TUV Bauart, CECP, cETLus, CU-EAC
Display Type
Energy Class
Class F
62 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.155 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
109% sRGB, 91% NTSC
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 75 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Lead-free, SmartImage, Low Blue Light Mode, Flicker Free technology, SmartUniformity, sRGB Mode, Delta E<2 calibration
Glossy black
61.3 cm x 19.2 cm x 46.1 cm - with stand
4.78 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DisplayPort , 2 x HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
26.1 W
26.1 kWh/1000h
Power Consumption (Typical)
20.22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.3 cm - depth: 19.2 cm - height: 46.1 cm - weight: 4.78 kg , Without stand - width: 61.3 cm - depth: 4.5 cm - height: 36.8 cm - weight: 4.18 kg
Shipping Width
66.3 cm
Shipping Depth
15.2 cm
Shipping Height
51.9 cm
Shipping Weight
6.84 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
