Philips 275C5QHAW/00 27" 1920x1080 VGA HDMI Monitor
Quicklinx: BYZ1WS00 Mfr#: 275C5QHAW/00
The Philips Moda 2 combines stunning visuals with the convenience of a Bluetooth speaker system in one refined package. Easily stream your music and take calls from the powerful Bluetooth speaker system, to expand your experience.
  • AH-IPS technology
    AH-IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, AH-IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • Full HD
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
  • Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Powerful speakers
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc. depending on model and design.
  • SRS WOW HD
    Small speakers on most monitors often result in "ho-hum" audio experience. Philips monitors specially tuned with SRS WOW HD, transform your sound experience into an immersive, thrilling event.
  • Incredible surround
    Incredible Surround Sound technology produces embracing multi-channel surround sound with stereo speakers, without the constrains of room size and the clutter of wires. It delivers an impressive virtual 5.1 sound for immersive movie experience and musical enjoyment.
  • Bluetooth streaming
    Experience the wireless freedom of Bluetooth technology. Quickly pair your mobile device to the monitor Bluetooth speaker and easily play your favorite music, or even use for hands-free speakerphone calls.
  • MHL technology
    Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
  • Super narrow border
    Utilizing latest technology panels, these Philips displays are designed with minimalistic approach by limiting the outer bezel thickness to about 2.5 mm. Combined with in-panel black matrix strip of only 3.5 mm, the overall border dimensions are reduced significantly allowing for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow bezel display gives you the feeling of using one large display.
Philips Brilliance C-line 275C5QHAW - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
24 W
Microphone
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 14 ms (typical)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
Glossy white
61.3 cm x 23.8 cm x 46.7 cm
5.67 kg
Environmental Standards
ENERGY STAR Qualified
ISO9241-307, Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, CCC, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
Display Type
Energy Class
Class A+
34 kWh
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, power off timer, sRGB colour management, HDCP, SmartContrast, SmartImage, power on timer, Incredible Surround, SRS WOW HD, Flicker Free technology, Mercury free
Glossy white
61.3 cm x 23.8 cm x 46.7 cm - with stand
5.67 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
7 Watt
Input
Microphone
VGA , 2 x HDMI , Microphone , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), Stereo Bluetooth Wireless Technology, 360° Flip Design
MTBF
30,000 hour(s)
Power Supply
External
Input Voltage
24 W
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 61.3 cm - depth: 23.8 cm - height: 46.7 cm - weight: 5.67 kg , Without stand - width: 61.3 cm - depth: 4.2 cm - height: 37.2 cm
Sustainability Information
ENERGY STAR Certified
20 - 80%
