The Philips PowerSensor display using 85% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Webcam pops up when you need it; secures down when you don't
Webcams are great for connecting with others and collaborating on that important project. Sometimes, though, you don't want a webcam looking down on your desk. Our ingenious new pop-up webcam design pops up when it's time for meetings and for security tucks away nicely when you are not using it. -
IPS technology for full colors and wide viewing angles
IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
Crystalclear images with Quad HD 2560 x 1440 pixels
These Philips screens deliver Crystalclear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like USB-C, Displayport, HDMI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images. -
Narrow border display for a seamless appearance
The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display. -
SmartConnect with DisplayPort, HDMI and VGA connections
With a plethora of connectivity, these Philips displays come equipped with multi connections like VGA, Display Port, universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. USB connections ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon! -
DisplayPort-out for connecting additional displays
With DisplayPort-out you can connect multiple high resolution displays with just one cable from your first display to the PC. The ability to daisy chain multiple displays enables you to create a clean desktop without the hassle of too many wires all over. -
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life. -
LowBlue Mode for easy on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartErgoBase enables people-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional.
- Philips Brilliance B-line 272B7QPTKEB - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/394019
- Energy Class
- Class F
- Energy Consumption per Year
- 54 kWh
- Power Consumption (On mode)
- 26.2 W
- 2.0 megapixel camera, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 61.4 cm x 25.7 cm x 54.8 cm
- 7.86 kg
- Environmental Standards
- TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, cETLus, Ukrain Safety, CU-EAC
- Display Type
- Energy Class
- Class F
- 54 kWh
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 99 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- sRGB colour management, PowerSensor, SmartResponse, SmartImage, edge-to-edge glass, Smart Ergo base, SmartConnect, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, Sync-N-Go
- Textured black
- 61.4 cm x 25.7 cm x 54.8 cm - with stand
- 7.86 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DisplayPort , Headphones , Audio line-in , 3 x USB 3.0 downstream , HDMI , USB 3.0 upstream , Mini DisplayPort , DisplayPort output
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x HDMI cable , 1 x Mini DisplayPort cable , 1 x USB cable
- MTBF
- 70,000 hour(s)
- Input Voltage
- 26.2 W
- Power Consumption SDR (On mode)
- 26.2 kWh/1000h
- Power Consumption (Typical)
- 20.7 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.86 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 5.44 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
