This Philips monitor offers a simple, one-cable laptop docking solution. One USB dual-mesh cable with Type C and A connectors delivers video, Ethernet, power charge and DisplayLink functions. Windows Hello webcam offers greater security.
USB Docking
Philips USB-docking monitors deliver universal port replication for simple, clutter-free notebook connection. Securely connect to networks and transmit data, video and audio from a laptop using just a single USB cable. What's more, you can dock with a USB Type-C port for additional power charging. With docking monitors with built-in DisplayLink Technology, users can benefit from forwards and backwards USB compatibility with virtually any recent notebook. USB docking can boost business productivity and reduce costs.
- Philips B Line 272B7QUBHEB - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Energy Consumption per Year
- 61 kWh
- Power Consumption (On mode)
- 21.7 W
- Microphone, 2.0 megapixel camera, Gigabit Ethernet network adapter, USB 3.2 Gen 2 hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 114% NTSC, 132% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Black texture
- 61.4 cm x 25.7 cm x 54.8 cm
- 7.52 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, WEEE, EPA, cETLus, CU-EAC, DisplayPort 1.2
- Display Type
- Energy Class
- Class E
- 61 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 76 Hz
- Horizontal Refresh Rate
- 30 - 114 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Sync on Green, Lead-free, PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, EasyRead, Ultra Wide-Color Technology, sRGB Mode, Windows 10 Hello
- Black texture
- 61.4 cm x 25.7 cm x 54.8 cm - with stand
- 7.52 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , HDMI , USB-C 3.2 Gen 2 (power up to 65W) , DisplayPort output , USB-C 3.2 Gen 2 upstream , 3 x USB-C 3.2 Gen 2 downstream , USB-C 3.2 Gen 2 downstream (fast charging) , Network (RJ-45) , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 2 x DisplayPort cable , USB-C to USB-A cable
- MTBF
- 70,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 21.7 W
- Power Consumption SDR (On mode)
- 21.7 kWh/1000h
- Power Consumption (Typical)
- 25.6 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- Dimensions & Weight Details
- With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.52 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 5.1 kg
- Shipping Width
- 69 cm
- Shipping Depth
- 25.2 cm
- Shipping Height
- 45.8 cm
- Shipping Weight
- 10.27 kg
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 80%
