The Philips ErgoSensor is the first monitor with smart features that address your individual ergonomic requirements and overall health. The ErgoSensor takes care of wellbeing in three key ways. It does this using a processor connected to a CMOS sensor. Sophisticated algorithms for human-environment interaction analyze the pictures and displays a message on the screen.
Philips SoftBlue is a revolutionary technology reducing the intensity of the harmful spectrum of the blue light from computer screens. The harmful wavelength of blue is defined from 380 nm to 450 nm. SoftBlue changes the peak of the blue-chip in the LED from 450 nm to 460 nm. In such way SoftBlue removes 90% of eye-damaging blue wavelength. Also ensuring that the overall color integrity is retained.
Everyone wants to do their part to save the planet, but sometimes daily life gets in the way of your best intentions. Philips designs clever solutions that do the thinking for you. The PowerSensor is a smart monitor technology with a built-in "people-sensor". Infrared signals detect the presence of a person in front of the monitor and automatically reduce energy consumption by up to 80% the minute they walk away. So every meeting, coffee break, trip to the printer and chat with a coworker is an opportunity to reduce your carbon footprint and operating costs. Effortlessly.
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button! -
Built-in stereo speakers
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain. -
PowerSensor
PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life -
Zero power consumption
At the flick of the 0 watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further -
IPS technology
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
2 Ports USB 2.0 HUB
USB Hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, Web camera, PDA, Printer and many other devices which have USB connection available. The conveniently located USB 2.0 Hub on the monitor allows USB 2.0 signals to pass through to the computer. Note that many devices like cameras and HDD may need to be powered On independently, as they have higher power requirements than the monitor USB Hub can provide. -
DisplayPort
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
- Philips 231B4QPYCB - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Environmental Standards
- ENERGY STAR Qualified
- EPA 6.0
- Display Type
- Diagonal Size
- 23"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- PowerSensor, SmartResponse, SmartContrast
- Black
Audio
- Speakers - internal
- VGA , DVI , DisplayPort , 2 x USB 2.0 , Headphones , Audio line-in
Mechanical
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- EPA 6.0
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20.2 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- Philips SmartControl Premium
Sustainability Information
- ENERGY STAR Certified
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £22.43 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £14.85 |
