Philips 23" Brilliance IPS LCD Monitor Blade 2 Full HD Silver
Quicklinx: 8M0XWS00 Mfr#: 239C4QHSW/00
The Philips Blade 2 monitor with stylish, ultra slim design and wide view IPS display is ready for brilliant performance.
  • IPS technology
    IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Image, Entertainment, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
  • Stylish, ultra slim design
    New range of Philips monitors use the latest new generation ultra slim LED, thereby allowing designs to be much more slimmer than previous generation. Slim looks not only allow the monitors to look asthetically pleasing, but also saves space on the desk!
  • SmartKolor
    SmartKolor is a sophisticated color extension technology that is able to enhance visual color range of the display. By boosting RGB gain level of the display, this feature enables you to have rich, vibrant images for experiencing outstanding photos and videos.
  • SmartTxt
    SmartTxt is a sophisticated algorithm that enhances reading of text based application such as PDF documents or ebooks which usually requires more focus and concentration.
  • SmartContrast ratio 20000000:1
    You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent blacklevel and accurate rendition of dark shades and colors. It gives a bright, lifelike picture with high contrast and vibrant colors.
  • HDMI ready
    A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input, high quality digital video and audio signals all transmitted over a single cable from a PC or any number of AV sources including set-top boxes, DVD players and A/V receivers and video cameras.
  • Touch controls
    Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, Touch control gives the monitor a modern feel modern free.
Philips Brilliance Blade 2 239C4QHSW - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class C
Energy Consumption per Year
42 kWh
Power Consumption (On mode)
29 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
White
55 cm x 18 cm x 42.1 cm
3.05 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
3-year warranty
Display Type
Energy Class
Class C
42 kWh
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, SmartResponse, SmartContrast, SmartImage, Turbo mode, SmartKolor, SmartTxt
White
55 cm x 18 cm x 42.1 cm - with stand
3.05 kg
VGA , 2 x HDMI
Mechanical
Tilt
Tilt Angle
-3/+15
MTBF
30,000 hour(s)
Power Supply
External
Input Voltage
29 W
Power Consumption (Typical)
28.5 Watt
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 55 cm - depth: 18 cm - height: 42.1 cm - weight: 3.05 kg , Without stand - width: 55 cm - depth: 3.4 cm - height: 33.7 cm - weight: 2.07 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
