The Philips ergonomic LED display using 25% recycled materials and PVC, BFR free housing is ideal for Eco-friendly productivity.
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for Eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for Eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button! -
TrueVision
TrueVision is a proprietary Philips technology that uses advanced algorithm for testing and aligning monitor display which gives you the ultimate display performance that is 4 times more stringent than Windows sRGB requirements. -
Zero mercury content
Philips monitors with LED backlighting are free of mercury content, one of the most toxic natural substances which affects humans and animals. This allows for an Eco-friendly display throughout its life-cycle from manufacturing to disposal. -
Touch controls
Touch controls are intelligent; touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, Touch control gives the monitor a modern feel.
- Philips S-line 220S4LCB - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black with black stand
- 50.4 cm x 22.7 cm x 50.9 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartContrast, SmartImage, TrueVision, SmartPower, Touch Control, Smart Ergo base
- 50.4 cm x 22.7 cm x 50.9 cm - with stand
- 5.2 kg
- VGA , DVI-D (HDCP)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 15.7 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- Included Software
- Philips SmartControl Premium
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7
- Dimensions & Weight Details
- With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £9.15 |
