The TruVue TRVT561 provides a sleek and tidy mobile solution for 32"-60" displays. Complete with 2 heavy duty poles to display the screen at a maximum height of 1500 mm (59").
Its unique and convenient TV height adjustment is complimented by spring plunges providing 90-degree adjustments for landscape and portrait viewing, cable management, and 4 heavy duty braked caster wheels. The TRVT560 also comes with a spacious metal shelf for AV components.
- Height Adjustable Max: 1530mm (60.2")
- Universal VESA® 200x200 up to 600x400mm
- Plastic component shelf for AV equipment
- Internal Cable Management; hide cables to provide a tidy look.
- Smooth matt black finish
- Includes height adjustable VC Shelf
Height Adjustment
Adjusts & Locks Position
Creates a clean, professional installation while protecting and organising the cables
x4 Locking Caster Wheels
Provides stabilty
- Peerless Tru Vue TRVT560 cart - for flat panel - powder coat, smooth matte black
- Product Type
- Cart
- 84.1 cm x 72 cm x 117.9 cm
- Adjustments
- Tilt
- 30 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-60"
- VESA Mounting Interface
- 200 x 200 mm, up to 800 x 500 mm
- Max Load Weight
- 45.5 kg
- Powder coat, smooth matte black
- Wheels Qty
- 4
- 5-year warranty
- 84.1 cm
- 72 cm
- 117.9 cm
- 30 kg
AV Furniture
- Cart
- Recommended Use
- Flat panel
- Cable Management
- Integrated cable management
- 32"-60"
- Adjustments
- Tilt
- Max Load Weight
- 45.5 kg
- Wheels Qty
- 4
- Adjustable height, locking casters, portrait to landscape movement, metal shelf
- Limited warranty - 5 years
