Peerless-AV SR598 SmartMount Flat Panel Cart for 55" to 98" Displays
Quicklinx: BCS3WS00 Mfr#: SR598
Accessory Type: Trolley
13 in stock
£631.00 ex VAT
£757.20 inc VAT
The SR598 Flat Panel TV Cart has been redesigned to include all of the features you may need, making it perfect for any application. Mobility, appealing design, display height adjustment, pre-assembled base and UL certification ensure quick assembly while providing a ridged, but attractive, structure that fits into any decor. The 4" castors make it easy to move from room to room while the UL certification ensures you that it can be done with safety in mind.
Designed to meet ULĀ® certifications, the SR598 incorporates safety and security, ensuring you get the job done correctly.
Additional Features
  • Display can be located anywhere along the column for perfect viewing height (up to 60" at center)
  • Integrated cable management protects, contains and conceals cables for a clean, professional installation
  • Maneuvers easily on 4" (102mm) swivel casters, two locking
  • Pre-assembled base provides rigidity, stability and quick assembly
  • Textured black powder coat finish helps hide finger prints and dust
  • Open frame display adaptor helps prevent display input interference
  • Optional ACC-MS component shelf can be positioned anywhere along either column by simply lifting and repositioning
  • Universal mount fits displays with mounting patterns from 200 x 200mm up to 900 x 600mm
Plumb Adjustment
5 degrees of negative adjustment keeps even the heaviest of displays level
Open Frame Adaptor
Helps prevent display input interference
UL/CUL Certified
Provides the highest level of safety
Vertical Adjustment
Display and optional component shelf can be located anywhere along the column (up to 60" at center)
Component Placement
Optional metal shelf or laptop tray can be located anywhere along either column assembly
Welded Base
Provides rigidity, stability and quick assembly
Safe and Easy Maneuverability
4" (102mm) swivel casters meet UL/CUL requirements
Peerless-AV SmartMount SR598 - cart
Cart
116.9 cm x 73.7 cm x 173.6 cm
Tilt
-5°
40.5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
55"-98"
VESA Mounting Interface
Up to 900 x 600 mm, from 200 x 200 mm
Max Mounting Pattern Size
981 x 608 mm
Max Load Weight
136 kg
Material
Aluminium
Black powder coat
Wheels Qty
4
5-year warranty
116.9 cm
73.7 cm
173.6 cm
40.5 kg
Material
Aluminium
Black powder coat
AV Furniture
Cart
Recommended Use
LCD / plasma panel
981 x 608 mm
Cable Management
55"-98"
Tilt
-5°
Max Load Weight
136 kg
Wheels Qty
4
Locking casters, swivel adjustment, swivel casters, security hardware
Limited warranty - 5 years
Resources
The following resources are available for the Peerless-AV SR598 SmartMount Flat Panel Cart for 55" to 98" Displays
Brand: Peerless-AV
Price Range Ex VAT: 500 - 750
