Peerless-AV SmartMount Universal Pivot Wall Mount For 22"-40" Displays
Quicklinx: 7MVHWS00 Mfr#: SP740P
Ideally suited for medium LCD screens, the SmartMount SP740P pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The SP740P allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
  • Flexible viewing
    The Peerless SmartMount Pivot Wall Arm offers an exceptional range of motion, allowing for comfortable viewing angles in any room setup.
  • Space-saving design
    With its wall-mountable feature, the SmartMount Pivot Wall Arm ensures a neat and uncluttered space, making it perfect for small to medium-sized rooms.
  • Easy installation
    Designed for simplicity, the mounting kit provides everything needed for a quick and hassle-free setup, ensuring your LCD TV is securely attached to the wall in no time.
Peerless SmartMount Pivot Wall Arm mounting kit - for LCD TV - black
Mounting kit - wall-mountable
Mounting Components
Pivot wall mount
Recommended Use
LCD TV
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
AV Furniture
Mounting kit
Mounting Components
Pivot wall mount
Recommended Use
LCD TV
Placing / Mounting
Wall-mountable
22"-40"
