Peerless-AV 50mm Extension Pole - 2.0m
Quicklinx: 7MX6WS00 Mfr#: MOD-P200
Designed particularly for professional AV applications the Modular Series includes excellent features that reduce installation time and maximize versatility.
  • Versatile mounting
    The Peerless Modular Series Extension Pole is designed to offer a flexible solution for your AV mounting needs. This extension pole can be easily integrated with other Peerless Modular Series components, allowing for a customized setup that meets your specific requirements.
  • Durable construction
    Crafted with high-quality materials, the Extension Pole ensures reliability and durability. Its robust design supports your AV equipment securely, providing peace of mind and a stable foundation for your displays or projectors.
Peerless Modular Series Extension Pole mounting component - chrome
Mounting component
Mounting Components
Extension pole
5.08 cm x 5.08 cm x 2 m
Chrome
5.08 cm
5.08 cm
2 m
Chrome
AV Furniture
Mounting component
Mounting Components
Extension pole
