Panasonic TH-80LF50ER 80" Full HD 1920x1080HDMI LED Display
Quicklinx: CBYJWS00 Mfr#: TH-80LF50ER
  • 1080p
High 700-cd/m2 brightness and 5,000:1 contrast ensure excellent, eye-catching visibility even in large public spaces. Ideal for digital signage applications.
This ultrathin design has a depth of only 89 mm. Its light weight also enables wall mounting, for greater installation flexibility.
  • Large screen and high brightness
  • Ultrathin 89 mm depth
  • High reliability
    The highly durable panel allows continuous, 24-hour use. The LED backlight also saves energy for extremely efficient operation.
Panasonic TH-80LF50ER 80" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
80"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Max Number of Screens
25
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote control, 2 AA batteries
Voltage
AC 230V (50/60 Hz)
380 Watt
Power Consumption Stand by
0.5 Watt
184.8 cm x 8.9 cm x 107.3 cm
60 kg
380 Watt
Diagonal Class
80"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode, 1:1 Pixel Mode, Seam Hides Video Mode
Dimensions
Without stand
184.8 cm
8.9 cm
107.3 cm
60 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Total Pixels
2,073,600
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Certified for 24/7 Continuous Operation, Automatic Picture Positioning, Input Search Function, Function Slot 2.0
Video Wall
25
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Remote Control
Remote control
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
Composite video input , 2 x audio line-in , HDMI input , Component video / RGB input , DVI-D input , VGA input , Audio line-in , DVI-D output , Serial input , Serial output , LAN , Audio line-out
2 AA batteries
GOST, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
Power supply
Input Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.3 Watt
Width (Shipping)
199.3 cm
Depth (Shipping)
34.9 cm
Height (Shipping)
118.8 cm
Weight (Shipping)
71 kg
20 - 80% (non-condensing)
