Philips 55BDL4150D 55" 3840x2160 8ms VGS DVI HDMI DisplayPort LED Large Format Display
Quicklinx: FMX3WS00 Mfr#: 55BDL4150D/00
TV Tuner Presence: No
Video Interface: HDMI
£1,251.16 ex VAT
£1,501.39 inc VAT
Make it stand out with a fast Philips D-Line Professional 4K UHD display. Philips superb picture quality ensures true colors and intense contrast. You can effortlessly display content from multiple sources on a single screen.
  • Powered by Android
    Control your Philips professional display via an internet connection. The integrated Android OS (SoC) lets you install web and native Android apps directly to the display. A built-in scheduler makes it easy to launch apps and content based on time of day, or user. Auto orientation ensures your content displays properly.
  • CMND & Deploy
    Quickly install and launch any app-even when you're off-site and working remotely. CMND & Deploy lets you add and update your own apps, as well as apps from the Philips Professional Display App Store. Simply scan the QR code, log in to the store, and click on the app you want to install. The app is automatically downloaded and launched.
  • CMND & Control
    Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • CMND & Create
    Take control of your content with CMND & Create. A drag-and-drop interface makes it simple to publish your own content-whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure your stills, text, and video will be up and running in no time.
  • Integrated mPCIe slot
    Easily connect 4G/LTE modules to your Philips professional display. The integrated mPCIe slot enables your display to communicate with other devices that share the same wireless connectivity. Invaluable if you're installing displays in locations such as banks or government buildings, where you cannot get onto the local network.
  • FailOver
    From waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
  • QuadViewer
    Turn a single Philips Professional Display into a bezel-free 2x2 videowall. By connecting four independent sources, you can effortlessly play multiple channels at once. Simply tell the display which zone should play which content. Ideal for situations like broadcast control rooms, where feeds from multiple cameras need to be clearly visible.
Philips 55BDL4150D D-Line - 55" Class (54.64" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Yes - digital signage
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, CMND management, FailOver
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Low Bright, 3D Combfilter
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
USB
3 ports
Remote control, batteries
Voltage
AC 120/230 V
Energy Class
Class G
120 Watt
Power Consumption (On mode)
151 W
Power Consumption Stand by
0.5 Watt
124 cm x 6.44 cm x 71.34 cm
25 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
120 Watt
151 W
151 kWh/1000h
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Series
D-Line
Platform
Android
Operating System
Android OS 7.1.2
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode
Dimensions
Without stand
124 cm
6.44 cm
71.34 cm
25 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1100:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
Commercial Features
Operation Hours / Days
24 / 7
3D MA deinterlacing
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1440 x 1050, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 640 x 350, 720 x 400, 848 x 480, 1152 x 900, 1360 x 768, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1400 x 1050, 1600 x 900, 3840 x 2160, 4096 x 2160, 960 x 720
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, TS, DAT, MPG, MPEG
Supported Audio Formats
MP3, WMA, AAC, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
USB Port
USB Ports Qty
3
Configuration
Rockchip RK3399 - 4 GB - 16 GB
16 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing
LAN
Connector Type
DisplayPort input , 3 x HDMI input , DVI-D input , VGA input , Audio line-in , Audio line-out , SPDIF output , Speaker output , USB , Remote control , DisplayPort output , RS-232C input , USB 3.0 , USB 2.0 , mPCIe slot , RS-232C output , Infrared output , Infrared input
Batteries
Serial cable
FCC Class A certified, UL, BSMI, cUL, CB, PSB, RoHS, RCM, CU
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
Limited warranty - 3 years
20 - 80% (non-condensing)
Brand: Philips
Price Range Ex VAT: £1000 - £1500
