This stylish design blends in with surrounding spaces and fills the screen with images. The 6.3 mm (0.25") bezel width of the LF80 series is less than half the 16 mm (0.7") bezel width of the LF60 Series. And the slim design makes the depth only 57 mm (2.3"). Since the LF80 series blends in with almost any surroundings and the screen is nearly filled with images, this display has a powerful, eye-catching impact.
Performance with 700 cd/m2 of brightness is required for some signage and other professional applications. This allows images to be beautifully displayed even in large, brightly lit spaces, such as train stations and airports.
There is very little change in color, compared with the VA panel, when the screen is viewed at right or left angles, so the images are crisp and clear. This is ideal for providing correct information to places with a lot of people present, such as public spaces and facilities.
- Panasonic TH-42LF80W LF80 - 42" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight - edge-lit
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Input lock, button lock, remote control user level
- Settings Cloning Capability
- Picture Enhancements
- Colour Enhancement, Colour Refiner
- Speaker System
- 2 speakers
- USB
- Remote Control
- Standard remote
- Voltage
- AC 230V (50/60 Hz)
- 155 Watt
- Power Consumption (On mode)
- 110 W
- Dimensions (WxDxH) - without stand
- 94.7 cm x 7.2 cm x 54.1 cm
- 15.3 kg
- Product Type
- 155 Watt
- 110 W
- Diagonal Class
- 42"
- Commercial Use
- Series
- LF80
- TV Tuner
- No tuner
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, 1:1 Pixel Mode, Dynamic Picture Mode
- Dimensions
- Without stand
- 94.7 cm
- 7.2 cm
- 54.1 cm
- 15.3 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Coating
- Anti-glare
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 700 cd/m²
- Widescreen Modes
- Zoom
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Backlight Life
- 60,000 hour(s)
- Certified for 24/7 Continuous Operation, MPEG Noise Reduction, Input Search Function, Fail Back
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 852 x 480, 1152 x 870, 1360 x 768, 640 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050, 1600 x 900
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Fast Ethernet
- Supported Consumer Electronics Control (CEC)
- PJ Link
- Connector Type
- Serial output , Serial input , Infrared input , Infrared output , VGA input , 2 x audio line-in , Composite video / component video input , Audio line-out , Network , 2 x HDMI input , DVI-D input , DVI-D output , USB 2.0
- Included Accessories
- 2 AAA batteries, 3 clampers
- IEC 60950-1, EN55024:2010, AS/NZS CISPR22:2009, EN 61000-3-3:2013, EN 55022:2010 Class A
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Power on delay
- Width (Shipping)
- 112.3 cm
- Depth (Shipping)
- 20.3 cm
- Height (Shipping)
- 74.3 cm
- Weight (Shipping)
- 20 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
