Panasonic TG8062 DECT phone - twin pack
Quicklinx: 7RZDWS00 Mfr#: KX-TG8062EB
The backlit big screen is easy-to-read, and helps to navigate through the simple menu clearly. The TFT LCD lets you see both characters and color images with a GSM-like clarity that wasn't possible with conventional STN displays. Up to couple of hundreds names and phone numbers can be entered and stored. The phonebook allows you to make calls without having to dial manually. You simply search for the name and select the number you want to dial.
One full charge of the battery will provide many hours of talking time before the battery will need recharging. When the handset is not being used but left off the base station, the charge will be retained for up to a couple of hundreds of hours before requiring a recharge. A high-precision error correction system ensures clear conversation with less sound glitches, allowing you to enjoy a smooth, error-free conversation even when you're far away from the base unit.
If you want other people in the room to join your conversation or you want to use the phone without holding it to your ear, no problem, just press the "speakerphone" button. The base station includes a built-in Telephone Answering Machine (TAM) that automatically answers and takes a message from the caller when you cannot answer the call yourself. This model's digital recording system captures many minutes of messages. You can see the message count without operating the handset. Voicemail messages can pile up while you're away. The handy counter is located on the base unit and makes it easy to see how many messages you have at a glance when you return home.
When a caller leaves you a message, the handset can display the caller's details in a list. This allows you to skip to particular messages by selecting the caller's details from the list on screen. When an outside call is being received, the caller information is displayed. Incoming Call Barring feature allows the unit to reject calls from specified phone numbers that you do not want to answer such as junk calls.
One touch Eco modes let you lower the power consumption by one touch pressing the eco button on the handset. In eco mode, the signal output is reduced compared to the normal mode. Off to bed or need to put the baby to sleep? Now it's simple to set times when you don't want the phone to ring so you will never be disturbed. Instead the handset will flash silently.
Panasonic KX-TG8062EB - cordless phone - answering system with caller ID/call waiting + additional handset - 3-way call capability
Cordless phone answering system with caller ID/call waiting + additional handset
Total Number of Wireless Handsets
2
Cordless Phone Standard
DECT\GAP
Answering System
Digital
Intercom
Speakerphone
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Transfer, Call Hold
Display
LCD display - colour - Yes
Display Features
Wallpaper
Display (2nd)
LED display - monochrome
Additional Handsets Qty
1
2
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID/call waiting
Max Handsets Supported
6
Multi-Handset Configuration
Phonebook transfer
Dialer Type
Keypad
Dialer Location
Handset
Conference Call Capability
3-way
Intercom
Speakerphone
Menu Operation
Function Buttons
Speakerphone button, recall button, navigator key, flash button
Volume Control
Ringer Control
Ring Tones
40
Polyphonic Ringer
Handset Locator
Indicators
Visual ringer light
Lighted Keypad
Additional Functions
Built-in clock, Alarm, call barring, Time/Day Stamp, Intercom, phonebook transfer
Additional Features
Autotalk, key lock, tone control, eco mode, night mode, voice enhancer
Phone Memory
Phone Directory Capacity
200 names & numbers
Dialed Calls Memory
10
Caller ID Memory
50 names & numbers
Answering System
Answering System Type
Digital
Outgoing Announcements Qty
2
Max Outgoing Message Length
150 sec
Recording Capacity
18 min
Message Counter Display
Services
Call Screening
Voice Prompts
Display
Display Location
Handset
Diagonal Size
1.45"
Colour Depth
16-bit (65000 colours)
Display Information
Battery status
Backlit
Wallpaper
Display (2nd)
LED display
Colour Support
Monochrome
Display Location
Base
Aerial
Internal
Headset jack
Placing / Mounting
Wall-mountable, table-top
Phone line cable
Belt clip, power adapter, phone charging stand
Phone charging stand + power adaptor - external
2 x battery - AAA type
Rechargeable - Nickel Metal Hydride
Included Qty
2
Talk Time
Up to 780 min
Standby Time
Up to 250 h
Recharge Time
7 hour(s)
Dimensions & Weight (Base)
11.5 cm
12.3 cm
4.8 cm
180 g
Dimensions & Weight (Handset)
4.8 cm
3 cm
16 cm
130 g
