In response to the increasing popularity of widescreen image viewing, including Blu-ray content, the PT-DZ570 features native WUXGA resolution for high-definition viewing. This brings you lifelike projection of intricate, highly detailed images.
When the output level of the source device fluctuates due to the performance of the device or its cable connections, the original black and white levels of the image content cannot be reproduced correctly. With the PT-DZ570, you can view the waveforms on the screen and adjust the settings either automatically or manually as you prefer.
The PT-DZ570 series can be easily operated remotely over a LAN, because it is done using the computer's web browser. Furthermore, the projector sends an email message to notify the operator when an error has occurred, or a lamp needs to be replaced.
The PT-DZ570 can simultaneously display images from two sources onto a single screen. For example, you can display a PC image on the left and a video image on the right. Taking advantage of the wide-screen projection, this function gives you a host of new application possibilities to explore.
RGB booster significantly improves color reproduction
The RGB booster achieves high image quality with levels of color reproduction and brightness that make each color stand out. It combines Panasonic's proprietary vivid color control technology with a lamp modulation drive system for a 1-chip DLP projector that produces bright and vivid colors. -
Vivid color control
This unique control technology optimizes the use of the color segment areas of the color wheel. It increases the brightness of each RGB color by minimizing the unallocated portions between the colors, to achieve truly vivid coloring. -
Lamp modulation drive system
With the advanced lamp modulation technology, the projector is now able to control the lamp intensity for each of the red, green, blue and white segments of the color wheel separately. Because the actual light output is controlled in relation to each color segment, light usage is optimized and color balance is obtained without lowering the brightness. This results in bright, vivid images with increased color fidelity. -
Full HD-ready WUXGA resolution
In response to the increasing popularity of widescreen image viewing, including Blu-ray content, the PT-DZ570 features native WUXGA resolution for high-definition viewing. This brings you lifelike projection of intricate, highly detailed images. -
Waveform monitor function
When the output level of the source device fluctuates due to the performance of the device or its cable connections, the original black and white levels of the image content cannot be reproduced correctly. With the PT-DZ570, you can view the waveforms on the screen and adjust the settings either automatically or manually as you prefer. -
Web browser control over a wired LAN
The PT-DZ570 series can be easily operated remotely over a LAN, because it is done using the computer's web browser. Furthermore, the projector sends an email message to notify the operator when an error has occurred, or a lamp needs to be replaced. -
Side-by-side function
- Panasonic PT-DZ570E - DLP projector
- DLP projector - 1080p
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 4000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHM 300 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 480i, 576p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1035/60i
- Power
- AC 120/230 V (50/60 Hz)
- 415 Watt
- 33.2 cm x 48.5 cm x 16.8 cm
- 8.5 kg
- Networking
- Ethernet
- Data Link Protocol
Projector
- Brightness
- 4000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 102 cm - 762 cm
- Throw Ratio
- 1.45 - 2.94:1
- Uniformity
- 90 %
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Video Bandwidth
- 162 MHz
- Display Format
- 2,304,000 pixels (1920 x 1200)
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHM 300 Watt
- Bulb life cycle
- Integrated de-interlacer (progressive scan), Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Side-by-Side, Detail Clarity Processor 3, Waveform Monitor, 3:2 pull down compensation, Deep Color, PJlink, 3D Color Management, digital noise reduction, RGB Booster, Vivid Color Control, DICOM Simulation Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.0-3.4
- Zoom Type
- Manual
- Zoom Factor
- 2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 60%
- Horizontal Lens Shift
- 10% / 10%
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, DVI
- Video Modes
Input Device
- External
- 1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-D input - 24+1 pin digital DVI , 1 x component video / RGB input - BNC x 5 , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - BNC , 1 x S-video input - 4 PIN DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x remote control input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Security Features
- Password protection, text superimposing
- ISO 9001, ISO 14001
- Voltage Required
- 415 Watt
- Power Consumption Operational (Standby)
- 15 Watt
- Software Included
- Drivers & Utilities, Wireless Manager Mobile Edition 5.5
- 33.2 cm
- 48.5 cm
- 16.8 cm
- 8.5 kg
- 0 °C
- 45 °C
- 20 - 80%
