Reflecting Panasonic's aim of providing technology that integrates easily into working lives, the KX-TCA285 DECT handset is slim and light, making it perfect for highly mobile, active professional environments.
To ensure efficient, comfortable and clear communication, the KX-TCA285 is equipped with a noise reduction function, which can be enabled at the press of a button. This function reduces surrounding noise and makes the speaker's voice far easier to hear and understand.
Additionally, the KX-TCA285 automatically adjusts the receiver volume to an easy-to-hear level if it detects noise when moving from a quiet place to a noisy place, providing comfortable voice calls without stress.
Because work in factories, the healthcare and retail industries often requires both hands to be used, it can be difficult to communicate while holding a phone. The KX-TCA285 supports Bluetooth, which enables you to communicate using a cable-free headset while working, leading to improved work efficiency.
- Panasonic KX-TCA285 - wireless digital phone - with Bluetooth interface
- Product Type
- Wireless digital phone - with Bluetooth interface
- Total Number of Wireless Handsets
- 1
- Compatible Platforms
- Panasonic KX-NS1000
- Cordless Phone Standard
- DECT
- Speakerphone
- Yes (digital duplex)
- Call Services
- Message Waiting Capability
- Display
- LCD display - colour - Yes
- Product Type
- Integrated Components
- Bluetooth interface
- 1
Phone Features
- DECT
- Call Services
- Multi-Handset Configuration
- Phonebook transfer via Bluetooth
- Dialer Type
- Keypad
- Dialer Location
- Handset
- Conference Call Capability
- Speakerphone
- Menu Operation
- Ring Tones
- 27
- Indicators
- Voice message waiting indicator
- Additional Functions
- Additional Features
- Noise reduction, vibration alert
Phone Memory
- Phone Directory Capacity
- 500 names & numbers
- Dialed Calls Memory
- 5
- Caller ID Memory
- 10 names & numbers
Display
- Display Location
- Handset
- Diagonal Size
- 1.8"
- Colour Depth
- 16-bit (65000 colours)
- Backlit
- Connections
- Headset jack / sub-mini-phone 2.5mm
- Included Accessories
- Belt clip
- Battery
- 1 x battery
- Technology
- Rechargeable - Lithium Ion
- Included Qty
- 1
- Talk Time
- Up to 780 min
- Standby Time
- Up to 200h
- Recharge Time
- 3 hour(s)
Dimensions & Weight (Handset)
- 4.85 cm
- 1.79 cm
- 12.75 cm
- 88 g
