This scanner can quickly convert a large number of documents into electronic data, so it provides smooth usage even in offices with many users. Scanning documents into data makes it possible to consolidate information, which improves work efficiency. And it lowers the cost of handling documents and reduces the space needed to store them.
Double-sided scanning of documents from business-card size all the way to A4 can be done with a single scan. Plus, double-sided scanning is done at the same speed as single-sided scanning. This eliminates the need to repeatedly turn the document over to the front and back to rescan, and prevents pages from being missed when scanning.
The active double-feed prevention roller reverses rotation the instant that the leading document leaves the paper feed section to prevent the double-feeding of documents that are stuck together.
- Panasonic KV-S1046C - document scanner - desktop - USB
- Document scanner - desktop
- Interface Type
- USB
- Scan Element Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- 216 x 297 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 45 ppm (mono) / 45 ppm (colour)
- Max Document Size
- 216 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, card scanner
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 75 sheets
- Duty Cycle
- 2000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits)
- 31.7 cm x 20.9 cm x 19.6 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty
- Interface Type
- USB
- 216 x 297 mm
Scanner
- Input Type
- 600 dpi x 600 dpi
- Scan Element Type
- Max Document Scan Speed B/W
- 45 ppm
- Max Document Scan Speed Colour
- 45 ppm
- Duty Cycle
- Scanner Speed Details
- 45 ppm - portrait B&W - A4 / Letter - 200 dpi , 90 ipm - duplex - portrait B&W - A4 / Letter - 200 dpi , 45 ppm - portrait colour - A4 / Letter - 200 dpi , 90 ipm - duplex - portrait colour - A4 / Letter - 200 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, double feed prevention roller system, Multi Color Dropout, Double Exposure, Image Emphasis, Gamma Correction, Automatic Separation, Noise Reduction, Mirror Image, Automatic Image Orientation, Long Paper Mode, Dynamic Threshold, Blank Page Removal, Error Diffusion, Patch Code Detection, Separation Sheet Detection, Automatic Binary / Color Distinction, Mixed Document Feeding, Dither, MultiStream Technology, Auto Crop, Auto Deskew, Remove Punch Hole, Dog-Ear Detection, Smooth Background, White Level from Paper, Detect Control
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 2540 mm
- Automatic
- 75 sheets
- Cables Included
- 1 x USB cable
- ISO 7810
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 25 Watt (8 Watt)
- Software Included
- Drivers & Utilities, Image Capture Plus
- OS Required
- 31.7 cm
- 20.9 cm
- 19.6 cm
- 4 kg
- Limited warranty - 3 years
- 15 °C
- 30 °C
- 20 - 80%
