This great 6 piece accessory pack gives you all you need to get started on the Wii Fit!
The Fiit Kit has a high quality, thick exercise mat to allowyou to achieve all those exercise moves in comfort. The re-chargeable battery pack for the Wii Fit pad comes with a USB cable that can plug into your Wiiconsole and allows you to charge the pack whilst you are using the Wii. So, now, there is never any need to run out of batteries when using your Wii Fit.
In order to protect the Wii Fit pad from dirt and scratches,the Fiit Kit also includes a high quality silicon cover that has been designed with textured foot grips to help prevent slipping from the pad whilst exercising. For additional safety, 2 pairs of exercise socks are included with textured grips on their soles.
Finally, to give you mobility for your Wii Fit, a strong, nylon travel bag is included.
The Fiit Kit contains:
-Wii Fit pad re-chargeable battery pack with extra length USB cable -Wii Fit pad silicon cover with textured foot grips -Travel bag for the Wii Fit pad -Extra Padded Exercise mat -2 Pairs of textured grip yoga socks
