Game loud and clear with the Xbox Wireless Headset, featuring enhanced auto-mute and voice isolation for crystal-clear chat, intuitive design, plus direct pairing to your console, PC, or phone.
- Game loud and clear with the Xbox Wireless Headset, featuring enhanced auto-mute and voice isolation for crystal-clear chat, intuitive design, plus direct pairing to your console, PC, or phone
- Surround yourself with spatial audio technologies including Windows Sonic, Dolby Atmos, and DTS Headphone:X*
- Dive into sound reimagined. Revealing depth, clarity, and details like never before, Dolby Atmos is a sound experience you can feel all around you.
- Enjoy up to 20 hours of battery life with the internal, rechargeable battery
- Be heard clearly with enhanced auto-mute and voice isolation that reduce background noise for crystal-clear chat
- Experience the flexible, lightweight design with an adjustable headband that provides a more comfortable experience during extended play sessions
- Rotate the earcup dials for a quick, intuitive way to adjust volume and game/chat balance
- Fine-tune your headset with the Xbox Accessories app for a customized audio experience*
- Pair directly to your console with Xbox Wireless radio without the need for dongles or a base station
- Connect to your PC or mobile device with Bluetooth® for on-the-go music or chat – even pair to your phone and Xbox simultaneously to chat with a friend on your phone while playing on your console
*See xbox.com/headset-compatibility. Audio customization available via the Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11 devices. Dolby Atmos and DTS:X: may require additional purchases, app downloads, and supported hardware. Battery life varies significantly with distance from console, additional accessories, usage and other factors. Testing conducted by Microsoft using pre-production units.
Advanced audio technology
Utilizes DTS Headphone:X and Dolby Atmos to deliver an audio experience, enhancing gameplay with spatial sound. -
Comfortable design
Full-size headphones with soft foam and polyurethane leather earpads provide hours of comfortable use during gaming sessions. -
Seamless connectivity
Equipped with Bluetooth 5.3 for quick and reliable wireless connections to gaming consoles and computers. -
Versatile controls
Features easy-to-use controls for mute, volume, and game/chat balance, allowing players to manage audio effortlessly. -
Long battery life
The rechargeable lithium-ion battery offers extended playtime, ensuring the headset is ready for gaming marathons.
- Microsoft Xbox Wireless Headset - headset
- Product Type
- Headset - Bluetooth - wireless
- Compatibility
- Windows, Xbox One, Xbox Series S, Xbox Series X
- Recommended Use
- Game console, computer
- Gaming
- Style
- Games
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- Sound Effects
- Windows Sonic spatial sound, DTS Headphone:X
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Impedance
- 32 Ohm
- Diaphragm Type
- Paper composite
- Microphone
- Boom
- Controls
- Power on/off, pair mode, mute, game/chat balance, volume
- Designed For
- Xbox One, Series S, Series X
- Product Type
- Compatibility
- Style
- Games
- 320 g
- Headband Material
- Foam, metal
- Earpad Material
- Polyurethane leather, foam
- Recommended Use
- Gaming
- Bendable microphone arm, LED indicator
Audio Output
- Full size
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC
- Bluetooth Version
- Bluetooth 5.3
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Hands-Free Profile (HFP), Headset Profile (HSP)
- Sound Output Mode
- Stereo
- Built-in Decoders
- Dolby Atmos
- Sound Effects
- 20 - 20000 Hz
- Impedance
- 32 Ohm
- Diaphragm
- Paper composite - 40 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Form Factor
- Headset microphone
Remote Control
- Controls
- Connector Type
- USB-C (power only) (24 pin USB-C)
- Supported Host Device OS
- Windows 10, Windows 11
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 20 hour(s)
- Run Time Details
- Continuous playback (with 30 min charge): up to 4 hours
- Recharge Time
- 3 hour(s)
- Designed For
- Microsoft Xbox One, Series S, Series X
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HX52 051377 Condition: Customer return - item has been used and shows signs of use |
£54.84 |
Ref:
HX52 051396 Condition: Customer return - item has been repaired under warranty by the manufacturer Please note: The box is damaged however the product is in perfect condition. |
£64.47 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
