Optoma Replacement Lamp for HD25e/HD131Xe
Quicklinx: 9W42WS00 Mfr#: SP.8VC01GC01
Marketing description is not available.
  • Enhanced brightness
    The 190 W UHP lamp ensures your presentations and videos are bright and clear, even in well-lit environments. Its high wattage allows for vibrant images, making it an ideal choice for any setting requiring a powerful projection.
  • Seamless compatibility
    Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup. Its compatibility ensures a hassle-free installation process, allowing you to get back to your presentations and screenings without delay.
Optoma BL-FU190E - projector lamp
Projector lamp - UHP - 190 Watt
10.2 cm x 10.2 cm x 10.2 cm
Optoma HD131Xe, HD25e
Projector lamp
10.2 cm - 10.2 cm - 10.2 cm
Lamp
UHP
190 Watt
