Optoma PMG+ - Projection screen 95" (241 cm) 16:10 Matte White
Quicklinx: BQTKWS00 Mfr#: DS-1095PMG+
£253.19 ex VAT
£303.82 inc VAT
Optoma PMG+ projection screens are popular because they are inexpensive and easy to operate.
  • Controlled screen return
    Optoma PMG+ manual screens feature speed reduction-retraction. Simply pull down lightly to release the locking mechanism, let go and the screen will slowly return to the casing.
  • Selflock
    Pull down the screen and hold for 3 seconds, then release. The screen will stay at the desired position.
  • Construction
    Optoma's matte white fabric is composed of 4 different layers, including a sheet of weaved fiber-glass which helps stop static electricity and most importantly prevent wrinkles and waves. The screen fabric consists of a special material that helps prevent the loss of light, making it compatible with virtually every projector. The fabrics are designed to be fire, water, and mold resistant and can be cleaned if required. The outside surface of the matte white screen has microdots that are made with PVC technology. This surface helps with creating the best possible reflection, whilst advances in screen technology help keep the matte white screen flat and retain its shape and effectiveness over longer periods of time.
Optoma DS-1095PMG+ - projection screen - 95" (241 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
95" (241 cm)
Projection Image Size
203 cm x 127 cm
Aspect Ratio
16:10
Screen Surface
Matte White
225 cm x 11.2 cm x 8.6 cm
11.3 kg
Projection screen
Placing / Mounting
Image Diagonal Size
95" (241 cm)
Image Width
203 cm
Image Height
127 cm
Screen Surface
Matte White
Aspect Ratio
16:10
Gain
1.0x
Border Size
5 cm
Extra Border Size
30 cm (top)
Self-locking roller
225 cm - 11.2 cm - 8.6 cm
11.3 kg
Type: Projection screen
Brand: Optoma
