Lamp modules supplied by Optoma are designed and tested to work specifically with your Optoma projector. Whilst copy lamp modules may carry original manufacturer's bulbs, Optoma specifically screens all its lamp modules to ensure the highest quality and longevity.
Enhanced brightness
The Optoma E20.8 elliptical projector lamp is designed to deliver an impressive 180 W of power, ensuring your presentations and media are seen in clear light. With such a robust capacity, it enhances the brightness of your projector, making it suitable for both professional and home environments where clarity is important. -
Seamless compatibility
Specifically engineered for compatibility with PC systems, this projector lamp integrates smoothly with your existing setup. Its precise design by Optoma ensures a perfect fit and optimal performance for your OSRAM series projectors.
- OSRAM E20.8 ellpitical - projector lamp
- Product Type
- Projector lamp - 180 Watt
- Designed For
- Optoma DS211, DX211, ES521, EX521
- Product Type
- Projector lamp
Lamp
- Capacity
- 180 Watt
- Designed For
