Enhanced brightness
The 190 W projector lamp ensures your presentations are vivid and bright, capturing the attention of your audience with clear, high-quality visuals. -
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
- Optoma projector lamp
- Product Type
- Projector lamp - 190 Watt
- Designed For
- Optoma DS303, DS328, DS330, DX330, DX5100, S303, W303, X303
- Product Type
- Projector lamp
Lamp
- Capacity
- 190 Watt
- Designed For
