Optoma PMG+ projection screens are popular because they are inexpensive and easy to operate. Optoma manual screens offer several outstanding features.
Controlled screen return
Optoma PMG+ manual screens feature speed reduction-retraction. Simply pull down lightly to release the locking mechanism, let go and the screen will slowly return to the casing. -
Construction
The screen fabric consists of a special material that helps prevent the loss of light, making it compatible with virtually every projector. The fabrics are designed to be fire, water, and mold resistant and can be cleaned if required. The outside surface of the matte white screen has microdots that are made with PVC technology. This surface helps with creating the best possible reflection, whilst advances in screen technology help keep the matte white screen flat and retain its shape and effectiveness over longer periods of time. -
Selflock
Pull down the screen and hold for 3 seconds, then release. The screen will stay at the desired position.
- Optoma PMG+ - projection screen - 109" (277 cm)
- Product Type
- Projection screen
- Placing / Mounting
- Ceiling mountable, wall mountable
- Projection Screen Image Diagonal Size
- 109" (277 cm)
- Projection Image Size
- 234 cm x 146 cm
- Aspect Ratio
- 16:10
- Screen Surface
- Matte White
- 16.71 kg
- Product Type
- Projection screen
- Image Diagonal Size
- 109" (277 cm)
- Image Width
- 234 cm
- Image Height
- 146 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:10
- Gain
- 1.0x
- Border Size
- 4.7 cm
- Extra Border Size
- 30 cm (top) & 4 cm (bottom)
- Black borders
- 16.71 kg
- Mounting Kit
- Included
- Water-resistant, fire resistant, washable
