This unique, portable screen is easy to use and very stable with high quality alloy casing and self standing format.
The Panoview Pull Up is an ideal screen for traveling, whether it's from room to room or around the country.
These screens are also great for rental companies were you're unable to mount a screen to the wall or a ceiling.
92" pull-up screen
92" diagonal 16:9 screen. -
Intelligent support bar and handle
For added strength and easy to pull up. -
Adjustable feet
Four individual feet to support and level the screen. -
Portable design
Lightweight and easy to setup at home or in the office.
- Optoma Panoview Pull Up DP-9092MWL - projection screen - 92" (234 cm)
- Product Type
- Projection screen
- Black
- Projection Screen Image Diagonal Size
- 92" (234 cm)
- Projection Image Size
- 203 cm x 115 cm
- Aspect Ratio
- 16:9
- Screen Surface
- Matte White
- 219 cm x 11.5 cm x 15.5 cm
- 7.5 kg
- 1-year warranty
- Designed For
- Optoma HZ40STx, UHD35x
- Product Type
- Projection screen
- Image Diagonal Size
- 92" (234 cm)
- Image Width
- 203 cm
- Image Height
- 115 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:9
- Gain
- 1.0x
- Extra Border Size
- 82 cm (bottom)
- Black borders
- 219 cm - 11.5 cm - 15.5 cm
- 7.5 kg
- Black
- Adjustable height
- Limited warranty - 1 year
- Designed For
