Optoma DS-9092PWC 16:9 Pull Down Projector Screen, 92 Inch
DUAL WALL AND CEILING MOUNTABLE!
Quicklinx: C3GDWS00 Mfr#: DS-9092PWC
Accessory Type: Projection screen
12 In Stock
£219.25 ex VAT
£263.10 inc VAT
PWC projection screens are popular because they are inexpensive and easy to operate. Optoma manual screens offer several outstanding features.
  • 92" Diagonal 16:9 Pull Down Screen
  • Self-Locking Mechanism
  • Dual Wall and Ceiling Mountable
  • High Quality Screen Materials
Optoma's matte white fabric is composed of 4 different layers, including a sheet of weaved fibre-glass which helps stop static electricity and most importantly prevent wrinkles and waves. The screen fabric consists of a special material that helps prevent the loss of light, making it compatible with virtually every projector.
The fabrics are designed to be fire, water, and mold resistant and can be cleaned if required. The outside surface of the matte white screen has microdots that are made with PVC technology. This surface helps with creating the best possible reflection, whilst new advances in screen technology help keep our matte white screen flat and retain its shape and effectiveness over longer periods of time.
Optoma PWC - projection screen - 92" (233.7 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
92" (233.7 cm)
Projection Image Size
203 cm x 114.5 cm
Aspect Ratio
16:9
Screen Surface
Matte White
Product Material
Aluminium, fabric, PVC, fibreglass
225 cm x 11.2 cm x 8.6 cm
11.3 kg
1-year warranty
Optoma HZ40STx
Projection screen
Placing / Mounting
Image Diagonal Size
92" (233.7 cm)
Image Width
203 cm
Image Height
114.5 cm
Screen Surface
Matte White
Aspect Ratio
16:9
Gain
1.0x
Viewing Angle
160°
Border Size
5 cm
Extra Border Size
30 cm (top) & 6 cm (bottom)
Product Material
225 cm - 11.2 cm - 8.6 cm
11.3 kg
Mounting Kit
Included
Water-resistant, fire resistant, mould resistant, self-locking
Limited warranty - 1 year
Optoma HZ40STx
Brand: Optoma
